ride height adjustment
I've tried to adjust my front ride height but no matter how many turns on the adjusting nut, nothing happens. I cannot see any thread on the shock barrel but can see from underneath, the thread on the adjusting nut. Can the ring inside spin with the nut? If so what is to be done short of taking the whole thing apart?
Petie3rd
if the adjuster is spinning the internal collar then the only thing you can do is take the shock apart clean the thread and use some green loctite to glue the internal collar to the shock,
i just went through this as well also consider getting another set of used inner collars 928 INTL has them. the new to your car collars should fit better
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
NO substitute
Also, keep in mind, when making there adjustments the car needs to be driven for a good bit before changes will reflect with ride height.
Yes, if you're spinning the collar, you have bigger issues, but once you are adjusting properly always allow for car to "settle" after being adjusted. Just an FYI... Last edited by SharkTech; 08-30-2010 at 05:52 AM.. |
Network Native
Lowering a 928 below stock is a dandy way to have all sorts of alignment and broken spoiler issues. Not a good idea for a street driven car, expensive in tires etc anyway.
Petie3rd
Superbird what adjustment are you trying to make higher or lower??
What was the ride height before you started??
| Tags |
| ride hieght adjustment , shock adjusting nut |
