turn signals causing emergency light
In the past year, someone working on my car made the turn signals and gas low signal trigger the emergency light signal. So....where should I start to fix this problem? Which wires got crossed up? Behind the steering wheel or should I start at the foot panel?
need more info,
what is happening when you you do this?? |
Get familiar with the electronics...get a current flow diagram or wiring diagram and determine all possible suitable wires (color and path) that are in the circuits. Then examine what wires (color and path) you actually have in the circuit. The someone may have not been careful while doing whatever they were doing...obviously...that is if they caused the problem, and if they did turn the someone into a somebody in your past. A shop doing electrical diagnosis/analysis can be costly...particularly if they are not competent on a 928. Jon |
| All times are GMT -8. The time now is 07:22 AM. |
