Don Mega
turn signals causing emergency light
In the past year, someone working on my car made the turn signals and gas low signal trigger the emergency light signal. So....where should I start to fix this problem? Which wires got crossed up? Behind the steering wheel or should I start at the foot panel?
Old 08-29-2010, 09:38 PM
Petie3rd
Mrmerlin's Avatar
need more info,
what is happening when you you do this??
Old 08-30-2010, 08:55 AM
SharkHead
JhwShark's Avatar
As stated...give detail on When and What conditions the event occurs as well as what the someone did??
Get familiar with the electronics...get a current flow diagram or wiring diagram and determine all possible suitable wires (color and path) that are in the circuits.
Then examine what wires (color and path) you actually have in the circuit.
The someone may have not been careful while doing whatever they were doing...obviously...that is if they caused the problem, and if they did turn the someone into a somebody in your past.
A shop doing electrical diagnosis/analysis can be costly...particularly if they are not competent on a 928.
Jon
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 08-30-2010, 09:46 AM
