What model# fuel pump are you CIS guys using
I was checking to see if I had the correct in-line fuel pump for my fairly newly acquired non running 82 Euro S (CIS). The one that's on it is a Bosch 0 580 464 045(flow rate 141 L/HR and operating pressure 400(KPA). The one that is supposed to be on it(according to PET and Bosch) is a 0 580 254 053 (fr=175 and op=500) or 0 580 254 967 (fr=168 and op=500). The one I have on it won't work will it? I think the pressure and flow rate would be too low. I don't think I have an in-tank pump due to the fact I see no wires coming out of the tank outlet.
The CIS system needs the higher flow rate to maintain proper system pressure. Also, a lower flow rate can contribute to hot start problems. I would go with the proper pump specified in PET (only one will match your configuration) or a 6.5 bar Pierburg pump.
Dennis |
The stock correct ones. CIS pump has that longer neck on it too. If you don't have the in-tank one then I bet you have another one in the rear fender somewhere.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Use the correct pump or the engine may "break up" under high load and RPM situations.
1984 928's w/ 5 speed Smoked Quartz Metalic 1982 928's Turbo w/ 5 Speed Platinum Metalic 1978 Euro Widebody w/ 5 speed Guards Red |
e.g. Dave's car: SharkSkin - Shark Attack Round Twenty - Fuel Tank Vent Line/Filter Refurb
Various manual S4's |
Porsche transitioned from a fender mounted pump to an under tank pump in 78. The early 928's that were manufactured for destination to hotter climates were equipped with a second in tank pump. The factory pumps did have the long neck which contained the internal check valve. The aftermarket Pierburg doesn't have the internal check valve but the 6.5 bar unit that I bought includes an external check valve and all of the required fittings.
Dennis |
I could be wrong, but I thought all CIS had 2 pumps.
My 78 with CIS , 5spd, has 2 pumps...one under the tank behind the black cover, the 2nd is in the pass' side rear wheel well right up by the tail-lights (not covered up)...you should be able to see it by just looking under there...i had to replace both pumps...if you start replacing that 2nd pump...you will be replacing fuel lines too....mine was as hard as rock...as soon as i tried to undo the in-line fuel lines they just fell apart on me...too dry rotted...i would say if there's no pump under the fender...someone has removed it and bypassed the lines to the filter/accumulator assembly ... CIS needs the 2 pumps to run right...(75-80 PSI) it will run on one pump...but give it some heavy gas and it will loose power (i know..lol)
PS...both pumps need the one-way check valves too
John ......... 1978 Porsche 928 5sp LSD 1982 porsche 928 5sp LSD Last edited by american-kiwi; 09-09-2010 at 02:44 PM.. |
