1982 928S
georges 928S's Avatar
RE: Throtle body loose
Hey guys,
i removed my spider intake to do a refresh and found out it is loose, it don't seem
normal to me, i can move it back and forth and up a little. is any one doing a
refresh that can check his and let me know please. Thanks in advance. Ed.
Old 03-05-2011, 11:52 PM
Network Native
Danglerb's Avatar
The whole assembly of throttle body and the U tube back to the air meter mount on isolators, rubber cylinders with a bolt stuck on each end. Over time the rubber gets hard the bolts detach from the rubber. Time to replace them.
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 03-06-2011, 12:29 AM
MPDano's Avatar
Hi George,
Mike is probably right but I didn't do anything with mine when I put my Spider back on. My TB is exactly as yours, just kinda goes all over the place when the Spider was out. Here's the thing though, the Spider Body has that coupler which will hold it steady. Also, the Maf holds it steady from the rear end. With both those parts holding, mine no longer moves.
Like I said, probably not the right way way but I just left mine as is and it's fine. But while your in there, you might as well get those bolt thingys that DanglerB is talking about.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 03-06-2011, 10:51 AM
Recovering dismantler
neil30076's Avatar
George, +1 on what Mike said, time to replace the rubber bumpers that hold the assembly in place. I do it on any spider/intake refresh I do, haven't found one yet that didn't have at least one broken.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 03-06-2011, 11:49 AM
Petie3rd
Mrmerlin's Avatar
you want to replace the rubber mounts otherwise the throttle assembly can fall out while your driving and cause the engine to die,
once you have it apart you may need vice grips to grasp the metal edge of the mounting stud to remove the mount
Old 03-06-2011, 01:10 PM
1982 928S
Re: Throttle body
Hi guys,
thank you for your help, i replaced one isolator the one close to the maf and you
wont believe it, it was cut in half. now its perfect and i feel alot better.
thanks Ed.
Old 03-13-2011, 08:16 AM
MPDano's Avatar
Originally Posted by georges 928S View Post
Hi guys,
thanks Ed.
Good deal. Although pics would make it easier for other users to follow.
How much were they? Removal/Install Procedures?
Old 03-13-2011, 08:23 AM
1982 928S
RE: throttle body
Hi Leo,
sorry i didn't take pictures, but the way i did it, i lift up the throttle body enough
to unscrew the bottom piece and take it out and put the new one the same way,
theres a total of three of them but if you replace one close to the MAF it will be
nice and tied. the isolators were $24.00 but you only need one, unless you have
removed the whole body then its easier to replace all three. Ed.
Old 03-13-2011, 08:36 AM
MPDano's Avatar
Definitely a thing to take care of when the Spider is out. Shoulda woulda coulda.
Old 03-13-2011, 08:44 AM
