Motorsport Ninja Monkey
Captain Ahab Jr's Avatar
CV Joint Measurement Help Needed
I have posted on another 928 Forum without any success so I'm hoping you 928 guys can help me out with a little project I've started.
I need an outboard driveshaft stub axle that uses a bolted CV joint rather than the later ones which are welded assembly as I want to use 930 CV joints. As 930 stub axle and wheel hubs are pretty thin on the ground I am looking for an alternative.
If my research is correct I believe the early 928's (not sure which years) used a bolted outer CV joint rather than the later CV joint housing which is welded to the outboard stub axle.
Can some one please tell me what is the outside diameter, bolt circle diameter and bolt sizes are for an early 928 CV assy.
Old 09-24-2010, 02:32 PM
Kyle C
I know 84 model years have bolt-on inner joints, but the outers are welded to the splined shaft which slides into the hub assembly. Not sure if the earlier ones are different.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 09-24-2010, 02:38 PM
