1982 928S
georges 928S's Avatar
Question Door Lock
Hi guys, when i lock drivers side door,my passenger door dont lock, is there a vacume problem and how do i fix it. thanks. Ed.
Old 12-04-2010, 12:06 PM
MPDano's Avatar
Early US cars used vacuum. Mine is an early Euro and has an electric motor that spins. You might be able to see it if you put your glass all the way down and remove the inside molding. If you need to get in a fix it, you'll need to remove the door panel.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 12-04-2010, 12:54 PM
Petie3rd
Mrmerlin's Avatar
what year is your car?
Old 12-04-2010, 02:01 PM
pcar928fan's Avatar
Only 78/79 had vacuum locks. My '84 had a passenger door lock that was stuck and would not cycle so if you tried to lock the drivers door it would turn, then try and cycle the passenger door and when that wouldn't lock it would unlock the drivers door. Once we got the passenger lock unstuck it was all good... Good luck to you.
James
80 928 EURO S GT Club Racer, 81 928 Light Blue, 82 928 Comp Pkg Arrow Blue, 84 928 S Ruby Red, 85 928 EURO S Guards Red, 88 928 S4 Dark Blue, 92 928 EURO GTS Polar Silver, 94 928 GTS Grand Prix White
Old 12-04-2010, 02:02 PM
1982 928S
door locks
Hi mrmerlin, i hope i pronounced your name right, its an 82 model wiessauk edition.
i hope this will help. Ed.
Old 12-04-2010, 05:03 PM
garylewa's Avatar
I had the same problem with my passenger door lock after following putting everything together after repaint. My issue was with the two "lock" fuses on top of the CE panel. I changed both of these out with new fuses and both locks work.
Old 12-04-2010, 05:04 PM
1982 928S
door lock
garylewa, i have 2 seprate keys one for drivers side and one for passenger side.
i dont know if this is the problem. i think one of the locks was at one time, but i
will check the fuses. P.S. what year is your car. Ed.
Old 12-04-2010, 05:42 PM
garylewa's Avatar
Mine is an '83 US
Old 12-04-2010, 07:18 PM
Petie3rd
Mrmerlin's Avatar
open the CE panel cover and look for 2 sets of red/ white stripe wires with black fuse holders.
They should be clipped to the top of the CE panel but can sometimes fall behind the panel.
These are 400ma fuses for the central door locks .
inspect both of them see if one is blown, and clean the ends of the fuses.
Old 12-04-2010, 07:21 PM
garylewa's Avatar
Thanks, Mr. Merlin, I was just about to write what you did above......
'83 928S - Basalt Black Metallic w/Cocoa Brown leather
Old 12-04-2010, 07:44 PM
garylewa's Avatar
When my locks were acting up the drivers side door would not lock when the key was inserted into the passenger side lock. The only result I got was the passenger side lock was stuck in a continual loop of locking and unlocking until I turned the key the other way. When I inserted the key into the drivers side lock the drivers door would lock but would not lock the passenger door. I thought the motor was bad and was prepared to bite the bullet and purchase another motor until I remembered to check the fuses for the door locks. I was removing a ton of poorly wired PO work during my restoration and remembered I had a couple of "shorts" during troubleshooting. Sure enough one of the door lock fuses was popped; I replaced them both and the locks have worked ever since.
Old 12-04-2010, 07:54 PM
My driver door key will not lock the passenger door ('90 gt). However, after locking the pass. door with the button, I can unlock them both with the driver door key. Am I correct that fuses would not be the problem in my case? Also, dash button locks both.
Old 12-05-2010, 10:18 AM
Petie3rd
Mrmerlin's Avatar
Jim you dont have these fuses.
Your lock cylinder sounds like its damaged.
You can try taking it apart to investigate.
The door panel may also need to come off ,
to get to the harness.
Also look at the wire harness thats in the door sheath,
a broken wire can also cause this issue
Old 12-05-2010, 10:48 AM
Thanks. I know the PO had the panel off and the lock cylinder out as some repair work was done on the door skin. Suspect you are correct that something is broken/loose in there.
Old 12-05-2010, 11:18 AM
