1978 928 - 9288200072
Lesson on Fuses
My car would not start last night and I had to get my son to help me tow it home - just a few blocks.
The problem was the fuse for the fuel pump. It visually looked good, but when I took it out the fuse material broke without hardly touching it. It is the circled fuse in the picture - I suspect it is an original fuse and almost seems like the fuse wire is made of lead.
I see that several of the fuses are really old and some are the wrong amperage. I'm going out now to buy a whole new set and will replace them all. I'll clean up the contacts at the same time. I read several times on this forum that this is one the first things you should do as a cheap way to prevent electrical problems, but as usual I procrastinated and learned the hard way.
1978 928 - 5 speed - no sunroof - Copper Brown Metallic - Cork Interior
Old 05-30-2011, 01:35 PM
Maleficio's Avatar
CE looks pristine, though.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 05-30-2011, 01:46 PM
Yes - I pulled it out a couple of weeks ago and saw that there were no water leaks from up above which is good news. But the fuses/relays are over 30 years old in many cases so are brittle and starting to fail.
Old 05-30-2011, 02:36 PM
JK McDonald's Avatar
Fuel Pump Relay -
Hey Vandenham, You may have noticed that the fuel pump relay (XVII) in your attached photo also has a fuse mounted directly to the top of the relay itself. I think all of the earlier models can use a relay with or without the additional fuse. I've seen some wiring diagrams that will include this fuse in it's circuitry and others that do not.
You definitely have done a great job cleaning your fuse panel up.
Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 05-30-2011, 05:06 PM
Thanks for the info on the fuel pump relay - it's good to know that it can be replaced with a newer relay.
I wish I could take credit for cleaning the panel, but it was like that when I first removed the wooden cover. I've only wiped off the dust. My big challenge these days is with the interior removing all the panels, gluing up the edges, fixing minor tears and cleaning up all the worn in grime.
Rick
Old 05-30-2011, 08:12 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Yes these fuses are something else.
Happened to me a week after I got the car.
In the last 2 years, I got 2 broken fuses (both on the 12V line feeding the coil).
They are all available (including the 5 amp) at Canadian Tire in pack of 5.
Do yourself a favor, change them by circuits (i.e. head light) and try them before moving to the next circuit. Also record any change that you do at a given position/circuit.
Who Will Live... Will See
Old 05-31-2011, 01:26 AM
Kyle C
Are those jumpers in the 2 empty relay slots on the bottom?
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 05-31-2011, 02:48 AM
Linderpat's Avatar
Altho your panel looks clean, I notice an indication of excessive heat at that blown fuse (look carefully above the fuse). This could be caused by several things, including a fuel pump starting to go bad. The most likely culprit is that the contact was loose or not clean.
I would pull the panel and do a complete panel R&R - clean everything real well (I mean by that electrical cleaning with an eraser or contact cleaner). There are several good write ups for this job, and it is not hard to do. Make sure all contacts are tight - loose fuse eqquals heat generation, and that could spell fire.
A good write up is here - SharkSkin - Shark Attack Round Four - Bzzzzzzt! Fuse/Relay Panel Reconditioning
Ed
85 928 5 spd (guards red over tan)
07 Shelby GT500 6 spd (torch red over two tone black and red leather)
Old 05-31-2011, 04:52 AM
I was originally planning to lightly clean the contacts and install new fuses, but after looking at the writeup I think I will remove the panel and clean each contact separately. Linderpat, you are correct that the blown fuse holder is showing signs of excessive heat. My fuel pump sometimes is noisy so is on my to do list. The fuse holder for #17 (Heater/AC Blower) is also showing some heat damage.
The relay positions XV (Starter Relay) and XI (AC Compressor) are both bridges/jumpers.
And to my fellow Canadian, I got some of the fuses at Canadian Tire and the others at Parts Source which I believe is a subsidiary of Canadian Tire.
Thanks for the support - it's great to slowly clean up the electrical gremlins and make everything work the way it is supposed to.
Rick
Old 05-31-2011, 05:48 AM
harborman's Avatar
Rick
I always hated those type of fuses. Best you can do is clean all those fuse contacts and replace all fuses with new ones. Check for any loose fitting ones and see if you can tighten the fit. Any bad contact may cause resistance which will cause heat and loss of power. Good luck with it.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 05-31-2011, 07:17 AM
MPDano's Avatar
Good find as that is one of the hard ones to find. I've replaced all my Fuses on both my Euro and S. They are very inexpensive and can save you from all the headaches of not knowing. I've bought the ones from eBay with Zero issues.
They are called GBC (I think) Fuses but I'm not seeing the Kit that carries all the different sizes.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-31-2011, 07:34 AM
