-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   window rattle cheap fix (http://forums.pelicanparts.com/porsche-928-technical-forum/586310-window-rattle-cheap-fix.html)
Nio 01-18-2011 12:32 PM
Cheap fix for the 928 window rattle. I found out that the lower plastic guide over the black rod tolerance changes and as the gap gets wider the window starts rattling. I used a thick plastic zip tie wrap to close the gap and took less than 10 minutes on each door. they come in different sizes from Home Depot or 99 cent stores. In the picture (taken from my camera phone) I'm pointing to it with a pencil. The good thing is you don't have to take the door panel off just pull the center cover near the door handle , tear the white nylon, and raise the window 3/4 up until you see the lower plastic guide and insert the tie wrap and lock it. I don't know how long it's going to last but it's an easy cheap fix and no more rattle. It has been 6 months and still no rattle. http://forums.pelicanparts.com/uploa...1295382731.jpg
1986 Porsche 928 32v 5speed Southern California
MPDano 01-18-2011 12:36 PM
Great MacGyver! I was wondering what part was the fix for that. Have you tried to price out the Original Part? Might be worth checking into. Regardless, great find and temp fix.
MPDano 01-18-2011 12:42 PM
Prices and part numbers from right here on Pelican.
Upper left: OEM-92853728902 $22
Upper right: OEM-92853729002 $22
Lower left: OEM-92853725902 $18.50
Lower right: OEM-92853726002 $18.50
Nio 01-18-2011 12:56 PM
Parts are cheap but labor is high.
MPDano 01-18-2011 01:09 PM
Labor price is just my time. Door Panel and Glass is very easy to remove in our cars. Try removing just a Door Panel from a BMW X5.
MPDano 04-13-2011 03:20 PM
Ok Nio, I finally got my Euro back and am going to do the zip tie thing as $40 isn't in my rattle budget.
