Nio Nio is offline
window rattle cheap fix
Cheap fix for the 928 window rattle. I found out that the lower plastic guide over the black rod tolerance changes and as the gap gets wider the window starts rattling. I used a thick plastic zip tie wrap to close the gap and took less than 10 minutes on each door. they come in different sizes from Home Depot or 99 cent stores. In the picture (taken from my camera phone) I'm pointing to it with a pencil. The good thing is you don't have to take the door panel off just pull the center cover near the door handle , tear the white nylon, and raise the window 3/4 up until you see the lower plastic guide and insert the tie wrap and lock it. I don't know how long it's going to last but it's an easy cheap fix and no more rattle. It has been 6 months and still no rattle.
1986 Porsche 928 32v 5speed Southern California
Old 01-18-2011, 12:32 PM
MPDano's Avatar
Great MacGyver! I was wondering what part was the fix for that. Have you tried to price out the Original Part? Might be worth checking into. Regardless, great find and temp fix.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 01-18-2011, 12:36 PM
MPDano's Avatar
Prices and part numbers from right here on Pelican.
Upper left: OEM-92853728902 $22
Upper right: OEM-92853729002 $22
Lower left: OEM-92853725902 $18.50
Lower right: OEM-92853726002 $18.50
Old 01-18-2011, 12:42 PM
Nio Nio is offline
Parts are cheap but labor is high.
Old 01-18-2011, 12:56 PM
MPDano's Avatar
Labor price is just my time. Door Panel and Glass is very easy to remove in our cars. Try removing just a Door Panel from a BMW X5.
Old 01-18-2011, 01:09 PM
MPDano's Avatar
Ok Nio, I finally got my Euro back and am going to do the zip tie thing as $40 isn't in my rattle budget.
Old 04-13-2011, 03:20 PM
