cam belt question
hi im new on here i,ve just put an 81 928 manual euro on the road and working my way through the usual issues i have purchased the new cambelt kit and plan to fit it soon.i have heard this early model 16v engine does no valve damage if the cam belt breaks unlike the 32v model is this true?
Old 03-13-2011, 04:11 AM
gbgastowers's Avatar
Mixed opinions- but I think the 80-82 Euro S models are non-interference.But what do I know....Gunar
82 928 Euro S 5 speed, sport seats,Moss Green/Champagne 04 996 C4S conv tip Polar Silver/Metropol blue
Old 03-13-2011, 05:40 AM
Pete R's Avatar
There is no guarantee. I've had early motors that weren't supposed to be interference but were. Machining the the head, different pistons, and even carbon build up could effect this. Your best option is to do the proper belt maintenance and just assume it is interference.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 03-13-2011, 05:55 AM
cheers for replies probably play safe and get it done asaphow long would it take for a good mechanic to fit the belt and tensioners
Old 03-13-2011, 08:29 AM
harborman's Avatar
The shop time indicated in mechanics book is about 10 hours I think. Doing it yourself the first time should not be a rush job. I have been given prices ranging from $1,000 to $2,200 depending on what they run into and who does it.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 03-13-2011, 02:53 PM
[QUOTE=harborman;5899355]The shop time indicated in mechanics book is about 10 hours I think. Doing it yourself the first time should not be a rush job. I have been given prices ranging from $1,000 to $2,200 depending on what they run into and who does it.[/Q wow thats alot of labour charge your model is probably a lot more involved to do than my 16 valve i hope
Old 03-14-2011, 01:06 AM
European Shark
riber.bentsen's Avatar
The cam belt change is about the same 16/32V vise. Remember, the two cams are chained together, so on the front of the engine there is near to no difference.
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 03-14-2011, 01:28 AM
928: Serial Enabler
16 V is pretty straightforward, consider doing it yourself.
84,85,86 928 cars
Old 03-14-2011, 04:25 AM
just thought the 32v would have twin cam pullies on each bank?
Old 03-14-2011, 06:29 AM
Changing out the water pump and timing belt waas my first exposure to 928 engines. The most difficult part of the job was cleaning off all the oil and grime on the front of the engine, while not flushing it into "wrong places". The second most difficult part of the job was keeping all the proper bolts and other fittings together (plastic sandwich bags with labels on each is a requirement IMO). While there are several good writes up on how to do the timing belts, (find one you like and use it carefully) keep in mind you will want to do replace the front crankshaft seal, the 2 seals in the thermostat housing, rebuild the belt tensioner completely, replace the idler pulleys, and replace the nylon bearings on the idler shaft, along with a NEW water pump. Parts here to do all this runs about $800. And most repair people here, who will do the job, do want $1200-2000 labor...and Landseer is very correct you can do it yourself...oh, you will need a flywheel lock as well as a robust 27mm socket to loosen and tighten the crank bolt. Check out SharkSkin - Shark Attack Round Twenty-Seven - Timing Belt/Water Pump for one very detailed write up on this process. By the way, many shops who might take on this job have never done one, so if you decide you don't want to do it you will need seek out a shop that really does work on 928's with some regularity.....understands them, and is willing to do the job RIGHT!
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red)
Old 03-14-2011, 06:37 AM
cheers for all the info ill be doing it myself i worked as a mechanic for 10 years and recently did my skyline,will take my time and cover all the points you have made.cheers
Old 03-14-2011, 09:31 AM
Petie3rd
Mrmerlin's Avatar
to add to this dont forget to rebuild the oil pump and replace the O ring and radial seal and 3 bolt O rings, use STP in the pump gears and on the shaft of the pump before you put it togther make sure the ring gear has the square edge facing to the block the little dots on the gears will confirm this.
Consider to update all of the gears and belt to Hi Torque Drive or curved tooth design.
If you do this then you will put on the updated oil pump pulley that is steel and remove the 1mm spacer behind the aluminum gear
Old 03-14-2011, 10:41 AM
holy lambim hoping shes bone dry in there with no play in bearings ect and just fit new belt and tensioners.do i need to strip out oil pump?
Old 03-14-2011, 12:16 PM
928 Newbie
dcrasta's Avatar
Porkentensioner is your friend.
Old 03-14-2011, 12:34 PM
928: Serial Enabler
No, but its a simple preemptive step.
Water pump almost assuredly, too. And here is where the enthusiasts have found a terrible weakness --- and we are fitting only brand-new water pumps with new castings and plastic impeller. Never a rebuilt one. Rebuilds are prone to failure with metal impeller striking and machining the block such that a pump can no longer cool the engine. Porsche spec unit is prohibitively expensive for most of us. Laso makes now a new one to enthusiast specifications. Beware new no-name unit or counterfeit (ebay deals).
Simple rebuild of tensioner is effective and required. Pivot bolt and associated expensive plastic bushings are a must!
Audi-based spring tensioner, mentioned above by dcrasta, is an alternative. I have one on a car, but have also rebuilt 6 cars using the original tensioner parts.
84,85,86 928 cars
Old 03-14-2011, 01:03 PM
Pete R's Avatar
+1 on what landseer said.
Your car has been going 30 years with the stock components. I wouldn't bother going nuts, changing tensioners and gears just for the sake of it. If an inspection determines that they are bad only then would I consider anything other than what's in there already.
Neon SRT4 track car
Old 03-14-2011, 02:34 PM
thanks again for all the advice will definitely go with a new waterpump, as was said above seems to be a weak spot lots of guys on here with bad water leaks from the pump.tks tmpusfugit for the link on doing the job. brilliant!!! exactly what i was looking for, very clear pics too.if anyones interested i,ll let you know how i get on doing the job..mark
Old 03-14-2011, 03:16 PM
