-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   82 is running again, but has new problems unrelated to voltage stabilizer. (http://forums.pelicanparts.com/porsche-928-technical-forum/597863-82-running-again-but-has-new-problems-unrelated-voltage-stabilizer.html)
Maleficio 03-19-2011 05:34 PM
Cuts out at 1400 RPM. After good and hot, stalls and won't run. Let it cool, fires up and runs 'til hot, stalls.
Read out Temp II: bad. Thermo switch: out of spec. AFM: 7 to 28 1K ohms low. Temp II can swivel within housing. Twisted, car fired up perfectly, no cut outs until I drove it a short while. Parked it. Will order new Temp II.
Sucks because I replaced it last summer. Cheap part, I guess.
Maleficio 03-19-2011 05:36 PM
Rev past 1400, no problems. Checked switches on throttle housing, good.
Maleficio 03-19-2011 05:39 PM
Cold start valve within spec, too.
Mrmerlin 03-20-2011 11:15 AM
order 4 53 relays as well as the temp2 sender then replace the relays one at a time i will be one of them is weak an once its hot it then gets an open you could also inspect the bases of all the relays for melted or smell for burning
Landseer 03-20-2011 01:41 PM
Order the thermo-time switch along with the relays!
Its similar in the way it mounts to the car, passengerside, but mounts front/back axis as opposed to up/down of tempII.
When you install, no teflon tape. Let them ground to the car.
Sounds like you used manuals to test temp II? each terminal to ground as opposed to across the terminals, right?
Maleficio 03-20-2011 03:03 PM
I read across the contacts and contacts to ground: wide open on all three.
I jumped the contacts in the connector, no difference. Lights off, won't run. I'm now back to the original gripe from three weeks ago when we had the extreme temperature spike and drop from 80 to 25 in 24 hours.
Landseer 03-20-2011 05:43 PM
I should read some resistance (ohms scale). No voltage.
Start with these sensors. Am assuming you've handled all the grounds by now, including inspection of battery ground cable and hot lead and little red wire on the hot lead. All mission critical.
Maleficio 03-20-2011 06:22 PM
Yep, grounds are good. I expect the car will run fine tomorrow. But will fail again.
The Temp II sensor is bad, but think I have more than one failed part.
Maleficio 03-20-2011 06:39 PM
I think the the thermo time switch may be bad, but can't remember the readings.
Swapped out the coil today, no joy.
Put water remover solution in the tank: no difference.
The car will run strong until fully warmed up, which takes a while, then after at temp starts to intermittently cut out, then finally hard stalls while cruising.
Maleficio 03-20-2011 06:41 PM
Only relay is ever hot to the touch: window regulator relay. Jumped the fuel pump relay sockets, pump runs. No joy.
Landseer 03-20-2011 07:02 PM
These are old. You've taken it from garage queen to outside-all-the-time.
Did you systematically clean all the ground points and refurb the CE panel and key relays?
All new fuses. All new sensors. New ignition switch...
Could also be in injector wire shorting intermittently or green wire.
Working on this stuff is pretty necessary.
All that performance enhancing stuff, not so much.
Mrmerlin 03-20-2011 07:42 PM
get into the fuse panel and make absolutely sure that you dont have an extra fuse or two plugged into a slot that should be empty,
this can cause voltage to back feed to other circuits possibly the window relay
Landseer 03-20-2011 11:20 PM
So can a melt on the back. Pull it.
Maleficio 03-21-2011 04:11 PM
I replaced the fuel pump relay: no joy.
But I can no longer hear the fuel pump running.
Would a dying fuel pump cause this problem? If the pump is bad, how can the engine get enough fuel to kick over a few times with pressure? Could the pump be putting out too little pressure?
I verified voltage out of the distributor.
Can anyone recommend a fuel pressure tester that won't cost a buttload?
Maleficio 03-21-2011 04:18 PM
I pulled the vacuum hose from the fuel pressure dampener and fuel spilled out of it. Would this cause enough of a pressure drop to prevent the car from lighting off?
Landseer 03-21-2011 04:20 PM
Its unmetered fuel. Will indeed cause no start or loss of power.
neil30076 03-21-2011 04:24 PM
Yes, WSM vol 1A section 20 page 4 - how to check fuel pump delivery on a AFC system , as in the 82. Requires no expensive tools or gauge, just a calibrated measuring jug!
neil30076 03-21-2011 04:25 PM
Fuel in the vacuum line = Bad damper, replace it!
Maleficio 03-21-2011 04:26 PM
It just dawned on me that having extra fuel sucked into the intake may be what's been causing the crazy rumbling at idle.
Maleficio 03-21-2011 04:27 PM
Thanks. :)
Looks like fixing this no start is forcing me to uncover all sorts of problems. I wonder how this car even ran before?
neil30076 03-21-2011 04:30 PM
see my post #18, above, replace the damper before checking the fuel delivery.
Landseer 03-21-2011 04:40 PM
A 30 year old car has lots that is ready to break.
That's the reason to replace the known-weak items whether they need it or not.
Its also the reason not to thrash one or add performance parts until fully sorted.
I've violated that once with my 85 and am still paying for the mistake.
JK McDonald 03-21-2011 04:42 PM
Good Catch -
Hey Maleficio, If the pressure dampener or either of the pressure regulators leaks internally, raw fuel is being dump back into the intake manifold. This will not only cause low fuel pressure but the unmetered fuel will gradually flood out the engine.
It sounds like you’ve found your problem.
Good Catch, Michael
Maleficio 03-21-2011 05:35 PM
It looks like I have two problems:
Bad pressure damper causing the no-start, and a dying fuel pump causing the hard stalling after running up to temp.
Cruising I could feel the pessure drop out as if an electrical contact was opening and closing very quickly. I've experienced this before with bad pumps and wiring.
Maleficio 03-22-2011 06:47 AM
There are three pressure dampers, right? Forward, passenger and driver sides, right? Are they all the same part number?
Landseer 03-22-2011 07:39 AM
No, but you probably need to use the Porsche PET to identify what you have.
lfausty 03-22-2011 10:32 AM
helpful diagram? and my pic-- when i had same systems, the diverter/damper (has screen,clean) red tape area the hose was ripped open (1), going down the bracket was unwelded (2) , the whole metal line holding from that top hose to the other end at cat. the line running upside the cat to the topside (3) think a check valve there , mine had a red piece of garden hose clamped into it. so the whole L metal lines where holding on by hoses and flopping. huge vac/air leak, stalled out , stays running when warm now , and blew alot of black smoke to clean cause pressure theres now air/fuel ratio good hps and no soot.
http://forums.pelicanparts.com/uploa...1300814929.jpg
http://forums.pelicanparts.com/uploa...1300814945.jpg
neil30076 03-22-2011 10:42 AM
Maleficio , you really need to get a copy of PET :-)
No, lfausty, it is not the same damper - in the FI system 10 is the damper, 28 are the regulators :
http://forums.pelicanparts.com/uploa...1300815758.jpg
Maleficio 03-22-2011 11:03 AM
Thanx, Neil. :)
Maleficio 03-22-2011 07:35 PM
I think my main pump is dead, and the reason the engine will fire for four to five explosions is merely from accumulated fuel vapors trapped in the charcoal canister.
I've run the tank dry three times now thinking I had enough fuel to make it to the Sunoco station. Running a tank dry, thus starving the pump shortens it's life. I figure I killed my own pump. Those pumps work hard, like the human heart.
Mrmerlin 03-23-2011 06:06 PM
duuude???
how are running the tank dry?
why are you running the tank dry?
you gotta be smarter than the car brother!
Maleficio 03-23-2011 06:36 PM
I didn't mean to. Mileage has lately been dropping causing me to over-judge the range.
I heard the pump running today, but it may be worn out. Will buy a pressure tester soon to verify.
neil30076 03-23-2011 06:43 PM
Where are you? There may be someone local who can help you get out of this mess!
Go put at least 5 gals in the tank and a can ( or 2) of your favorite fuel injector cleaner, and report back!
Maleficio 03-23-2011 06:55 PM
Tank is full, and has a bottle of Heet water remover/injector cleaner. I've run so much cleaner through it I wonder if I scoured the pump to an early death?
Maleficio 03-23-2011 06:58 PM
I'm actually looking forward to going through the car and slowly massaging it back to life. It's given me eleven months of reliable joy, it's time for me to give it something back.
Landseer 03-23-2011 07:15 PM
Good idea.
You still are one of the few guys that has been able to snatch a 928 sub 5K that had sat a bunch --- and immediately put it into service!
Take some time, fix the right stuff and help it last another 20 years.
Maleficio 03-23-2011 07:25 PM
Hell yeah, Landseer. It's an old fighter jet for the road. Designed to be driven forever.
Landseer 03-23-2011 09:22 PM
That's the spirit! Be thankful, too, its the 16V car. Still tightly packed, but a bit simpler.
Maleficio 03-24-2011 01:41 PM
I opchecked the fuel injection relay, works perfectly, consistently. Checked voltage at relay sockets: 12 volts for the relay switch, 3 volts for the coil. I don't think a 12 volt relay will operate very well with only 3 volts. This explains why I felt the fuel pressure dropping instantly and coming back up, over and over until it finally stalled out while cruising. And also why the car won't start: the injectors are not being commanded to operate, though the cold start valve is operating because it's powered by battery power, thus the little spurt of fuel from the cold start valve makes the engine explode a few times, then stall because the injectors are not opening.
Dang it, I should've read voltage from the hot socket to an external ground instead of the ground socket. Stupid. That way I could've proven if I had a ****ty internal ground or not.
I guess I need to pull the CE panel like Landseer said and figure out what's causing the high resistance before I have a fire in there.
I can't tell from the schematic. Does anyone know if the fuel injector relay gets it's coil voltage from the ignition switch circuit? All I can see is power coming from circuit "31". I don't know what that means.
Thanks.
JhwShark 03-24-2011 02:03 PM
Always Hot is 30, Switched Hot is 15, I believe 31 is wired to ground not a direct to ground; the control unit gets ground from its pin 35...The relay always has 30 available for 12v and once car is on, 15 provides the juice to energize the relay passing the 12v to the injectors. The control unit gives the other part ot the signal in the proper firing order 1&5, 2&6, 3&7, 4&8.
