harborman's Avatar
Cam Cover (Cylinder head Cover) removal
I have a slight oil leak on the bottom of the cover gasket. How difficult is it to remove the cover(s) and replace the gaskets? I would think all the gaskets need to be replaced at the same time.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 03-31-2011, 08:18 AM
MPDano's Avatar
How hard can it be? I see 32V engines powdercoated all the time. If it was really that hard, I think there would be a lot less Intake Powdercoating posted.
Also, while your in there, why wouldn't you replace "all" gaskets that are affected during the Cam Cover removal/reinstall.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 03-31-2011, 08:45 AM
harborman's Avatar
Well, I could not find the procedure in the manual I have. Yes, I would replace all the gaskets as one is also leaking around a plug hole at the rear.
1986 928S
32 valve engine
Old 03-31-2011, 08:55 AM
MPDano's Avatar
Take mega pics too. You never know when a 3rd 928 might lurk into my hands
Old 03-31-2011, 09:15 AM
Yes, the reason us 32 valve owners powder coat is that when our belts go and we pull the engine to fix the heads, it is easy then.
86.5 Porsche 928, 75 Porsche 914, 2.0, 2001 Boxster.
Old 03-31-2011, 01:25 PM
928: Serial Enabler
Its not too bad a job, but there is a good bit of disassembly.
Pick the right height so that you aren't leaning over all the time but still have access.
Good time for new plug wires. Else care not to nick the ones you have.
Having an accurate inch-style torque wrench is a good idea.
The 85 car is more treacherous due to the potential of breakage of the oddball studs used.
Its a little less likely to happen on the 86.
84,85,86 928 cars
Old 03-31-2011, 02:36 PM
harborman's Avatar
Thanks. I read it can be a bit tirckey. Something about bolts breaking. The leak seems to have let up so I may let it go until later. I did just buy a nice 1/4" drive clicker torc wrench for up to 200 inch pounds. I will have to order gaskets and all yet. Original plug wires still look good.
1986 928S
32 valve engine
Old 04-01-2011, 07:37 AM
Pete R's Avatar
only 85-86, then they wisely went to bolts.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 04-01-2011, 07:44 AM
