torque tube bearings
Hi
anyone known how far from the front of a manual torque tube the first bearing should be, ie from the engine end, backwards ?
Old 05-09-2011, 01:35 PM
MPDano's Avatar
Good question
You should post pics of this progress as I am sure other would like to see the process. Me too actually
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-09-2011, 01:39 PM
928: Serial Enabler
11 or 12 inches, best I can tell.
This link has very good pictures. If you can't see them, you might have to signup for rennlist, another forum that that has its own advantages and disadvantages.
SharkSkin - Shark Attack Round Thirty - Clutch, Torque Tube, Transaxle - Torque Tube
Hopefully you are using the Constantine Black Sea Engineering bearings for the car.
http://forums.rennlist.com/rennforums/928-forum/495798-bsr-and-d-928-super-bearing-and-clamp-photos-pricing.html
84,85,86 928 cars
Old 05-09-2011, 03:34 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
bearing up
I am also interested in your progress.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 05-09-2011, 06:29 PM
Hi
many thanks, thats a brilliant link. My front bearing has gone walkabouts towards the centre and is now 25" from the front (hence the vibration at 5000 rpm) !
I intend to add another bearing into the front end to support the shaft again - subject to obtaining another bearing ?
On a 1990 Gt Manual, will the torque tube come out without removing the gearbox ?
Old 05-10-2011, 08:51 AM
Hi
yesterday I managed to obtain another torque tube, which I have now taken to bits thanks to the link provided.
Interestingly the tube had the 6" bearing/support (which i thought was the centre support?) at the gearbox end and 2 normal bearings, 1 in the middle and 1 at the front, is this normal ?
1 of the bearings/carriers looks to be good so i will try and fit it to my existing tube when i have moved the gearbox back etc. I will report back with some pictures soon.
Old 05-14-2011, 02:20 PM
Petie3rd
Mrmerlin's Avatar
is that 6 in support a vibration damper? is it sliding easily in the TT
Old 05-14-2011, 06:14 PM
Hi
Yes it's the vibration damper and it was a good fit in the tube (the replacement tube). I will have a look at my Gt tube today.
Old 05-15-2011, 12:47 AM
928: Serial Enabler
Counting from front of car, should be between brgs 2 and 3 according to everything I read.
On a GT, if I possibly could afford it, I'd want the Constantine bearings and would leave the dampener out. Probably stretch your timeline out a ways due to shipping though.
84,85,86 928 cars
Old 05-15-2011, 05:22 AM
Here's a couple of pictures showing where the front bearing was on my car.
and one with the extra bearing going in. I managed to move the gearbox back enough to allow the torque tube clamp to be removed and the new bearing seated in place. I used a combination of a short length of 3" plastic pipe, a thin length of wood and a lump hammer to knock the bearing in.
I will report back when I have reassembled and test driven.
Old 05-15-2011, 02:26 PM
