-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   HELP... What is this sensor (http://forums.pelicanparts.com/porsche-928-technical-forum/603243-help-what-sensor.html)
FIREMN 04-16-2011 10:23 AM
I found this while doing the fuel line R&R.
it is located at the rear of the engine below the fuel cooler manifold that is attached to the fire wall.
one end is loose under the air box and the other goes into the "bellhousing"
it goes into the housing on the 3rd photo right next to the piece of leaf.
any ideas..
Any help is appreciated
thnx
John
http://forums.pelicanparts.com/uploa...1302974071.jpg
http://forums.pelicanparts.com/uploa...1302974297.jpghttp://forums.pelicanparts.com/uploa...1302974519.jpg
FIREMN 04-16-2011 10:32 AM
also....there was only 2 studs to bolt down the air box...wasnt there supposed to be another set of studs?
tmpusfugit 04-16-2011 12:54 PM
The plug is for a Porsche test tool that is no longer used......my airbox only has 2 studs....
FIREMN 04-16-2011 07:49 PM
thnx for the info..now that is one less thing to figure out..lol
