-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Injector Help (http://forums.pelicanparts.com/porsche-928-technical-forum/606908-injector-help.html)
EIPtuningR32 05-05-2011 03:08 PM
Injector Help
iam in the process of changing my injectors and i cant remove the injector from the thingy the injectors screw into. any ideas? i tried PB blaster, clamping and torquing but it didnt work. any ideas? should i just buy new ones? whats the part number?
http://i573.photobucket.com/albums/s...njector002.jpg
http://i573.photobucket.com/albums/s...njector001.jpg
MPDano 05-05-2011 03:19 PM
The Aluminum Collar pushes up towards the Injector Threads. It's the old dried up seal that is holding it down.
EIPtuningR32 05-05-2011 03:44 PM
wow, haha. thanks! mine are pretty beat up, do you know where i can get some new ones with the seals and everything?
MPDano 05-05-2011 04:27 PM
I got mine from 928 Intl (get new), but I am sure Pelican has them too.
EIPtuningR32 05-06-2011 11:30 PM
do you know what seals i need for the sleeves??
MPDano 05-07-2011 07:45 AM
You really need to download PET. Great stuff with Diagrams and Part Numbers
928 110 398 00 For the Seal
http://forums.pelicanparts.com/uploa...1304779428.jpg
928 110 399 02 For the Collar
http://forums.pelicanparts.com/uploa...1304779442.jpg
EIPtuningR32 05-07-2011 10:26 AM
woah! what is PET??? i have the porsche manuals, but not anything like that. where do i get it?
EIPtuningR32 05-07-2011 10:30 AM
and thanks for the help Dano. are the seals hard to put in the sleeves?
Mrmerlin 05-07-2011 11:30 AM
if you use some DOW Corning 111 on the o rings things will go much smoother.
Witch hunter may also have the parts your seeking
MPDano 05-07-2011 04:08 PM
Merlin, he is CIS. I doubt Witch Hunter has anything he needs since they don't touch CIS Injectors. I agree with Merlin on the Silicone as I use it most anything rubber. Even dry, they just slip inside the Collar, then you just slip the CIS Injector through that.
MPDano 05-07-2011 09:06 PM
Sending you a PM :cool:
EIPtuningR32 05-08-2011 09:53 AM
replied
MPDano 05-08-2011 11:12 AM
Originally Posted by EIPtuningR32 (Post 6009590)
replied
Replied back ;)
EIPtuningR32 05-08-2011 12:57 PM
awesome!
