-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   **MOST Common 928 Issues AND Fixes** (http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes.html)
proturn 02-20-2015 01:38 AM
Great info on the Sun Roof repair which I did last November whilst I had it in pieces I also replaced the sunroof inner lining as it was torn and used Super Glue to make sure the corners do not curl up again.
I have just encounted the battery flattening curse after I parked the car up over xmas and now after charging the battery I cannot get the motor to start turns over but no firing of cylinders does any one have a checklist to follow abnd track down the reason for dead motor. Could this be due to Battery about to die as its been flattened right down twicw in the past three months?
I am going to get a new battery to give me a good power source before I try to fire the motor again. any assistance would be appreciated . relays to test fuses to test and replace and a checklist to follow to cut out wasted effort and more flat batteries.
Ron
hitman3 03-12-2016 12:32 AM
Originally Posted by vandenham (Post 6566618)
benshabbat@gmail.com thank u
Issue/Problem - Cracked, dirty and faded leather seats.
Solution/Fix - Re-dye the seats (this example uses Leatherique products
Here is the starting point.
http://forums.pelicanparts.com/uploa...1329594020.jpg
Step 1 - wet sand the leather using the Prepping Agent from Leatherique. The Prepping Agent softens the dye on the leather making it sand off quite easily. I used 400 grit wet sandpaper. Here is how it looked after sanding.
http://forums.pelicanparts.com/uploa...1329594083.jpg
Step 2 - fill the cracks with the Crack Filler product from Leatherique. This is a white paste that goes into the cracks. I applied a couple of coats in the large cracks. Here is what it looked like after applying the Crack Filler before the second sanding.
http://forums.pelicanparts.com/uploa...1329594204.jpg
Step 3 - second sanding. I actually sanded, applied additional Crack Filler and sanded several times. I also ended up poking a needle into all the holes in the leather as the crack filler filled them in. Here is the result ready for dyeing.
http://forums.pelicanparts.com/uploa...1329594140.jpg
Step 4 - apply the dye. I tried using a brush on a sample piece but found it took three coats and used a lot of dye. I ended up using a pencil sprayer with my compressor to spray on the dye. For the most part, only two coats were needed. I bought "Cork" colored dye as that is the original color for my car. The seats had been replaced some time ago and were "Champagne". Here is the final dyed result.
http://forums.pelicanparts.com/uploa...1329594305.jpg
The final result:
http://forums.pelicanparts.com/uploa...1329594369.jpg
Hi can you tell me were I can buy the cork dye ? My email is benshabbat@gmail.com thanx
Stepana 08-28-2016 09:33 PM
pop up lights not going up or down for early 928's
If all other tests for relays, fuses, and light switch have been performed and headlamps still don't go up or down or both, then I would recommend removal of headlamp motor by removing (3) 10MM bolts and (1) 10mm nut just left of driver's side headlight under hood. Prior to removal, take photo of (4) terminals to headlamp motor. Once removed from car, carefully peel back rubber boot from motor. It will most likely reveal (2) diodes which are faulty. Buy new diodes from radio shack. Unsolder old ones and note location of white band on old diodes and resolder new ones in same direction and location.
P.S. make sure to hold the headlamp from crashing down to it's sockets prior to removal of 10 mm nut from headlight motor shaft.
Also prior to reinstalling, test by grounding the headlight motor housing, reconnect (4) wire terminals to headlight motor housing in correct order, and turn ignition switch to on( don't start car), then turn on headlight switch. You should hear and or see motor shaft spinning and stop. Now switch ignition off, remove terminals from battery. Reinstall headlight motor. This takes some practice.
I hope I helped some people, cause it worked for me.
Redcar928 06-11-2019 03:43 AM
can anybody help me with opening this list? #32 in particular
bigwizz 10-31-2022 03:31 AM
I think I will end up removing the seats. Besides, I might find some money or contraband (As I have yet to remove my rear seats in this car and I fear what may be lurking under them...)
cgraner 01-27-2023 08:00 AM
Nice. Where did you get the blue part?
Mercedes Air Cleaner Intake Hose 1170940382
https://eeuroparts.com/product/genuine-mercedes-benz/1170940382
Aviator50 04-21-2023 08:14 AM
Hi,
Just found this font of information today when my 79 wouldn't start.
Brilliant source of info, cheers to you all.
Pity some of the pictures have disappeared but still some good repair info.
Aviator50
globalwad 10-18-2023 08:56 PM
New 928 owner here, this is a great thread of super-valuable info. Thanks to all who contributed to it!
greg fladseth 12-24-2024 01:34 PM
'88 928, replacing the center vent handle (above heater/HVAC controls) the lever has to go thru bracket on the right and put the lever hole on the pin guide
where is the screw or ? that holds the bracket in place. Do you have to remove the glove box?
NeoAura 09-05-2025 02:55 AM
Sounds like you've already done some solid work on the sunroof, nice job sorting out the inner lining too.
Now, about the non-starting issue after the battery went flat, you're definitely on the right track by planning to replace the battery first. A weak or deeply discharged battery can cause all kinds of strange behavior, even if it *seems* to crank the engine fine. Low voltage can mess with the ECU, fuel pump, ignition, and sensors.
