-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   **MOST Common 928 Issues AND Fixes** (http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes.html)
MPDano 05-06-2011 09:00 PM
Post "Known" Common Issues and the Fixes. Pics are a Plus :D
Please try and stay with the same Format. Issue - Fix - Pic (if any)
Index:
1) 14 Pin Connector: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes.html
2) Grounds: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes.html
3) Headlights not going down: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes.html
4) Splash Guards (Homemade): http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes.html
5) Broken Wheel Locks: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes.html
6) CIS - Hesitation on throttle up: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes.html
7) AC non-op in hot weather: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes.html
8) Transmission slipping: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-2.html
9) Electrical short tip: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-2.html
10) Measuring Tranny Pressures: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-2.html
11) Sunroof non-op: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-2.html
12) Low Alternator Output: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-2.html
13) Dim Instrument Panel Lights: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-2.html
14) Brake Booster Vac Line Alternative: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-2.html
15) HVAC Controller Buzz: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-2.html
16) Clutch Fan Alternative: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-3.html
17) Fuel Lines Replacement: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-3.html
18) Removing Rear Bumper: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-3.html
19) Aluminum Ball joints: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-3.html
20) Front Seat Sagging: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-3.html
21) Famous Green Wire (no spark or weak spark): http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-3.html
22) Bass Speaker in Spare Tire: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-3.html
23) Engine Specs by year and location (US/Euro): http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-3.html
24) Front Shock Replacement: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-4.html
25) CV Joint Rebuild: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-4.html
26) S4 Wing Install on OB: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-4.html
27) Oil Temp Gauge install: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-4.html
28) Wideband O2 and Gauge install: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-4.html
29) AC Compressor R12 convert to R134: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-4.html
30) Odometer non-op (bad gear): http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-4.html
31) Passenger area clicking noise: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-5.html
32) Manual Ball Cup Replace: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-5.html
33) Leaky Fuel Tank Repair: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-5.html
34) Motor Mounts R&R: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-5.html
35) Battery Shut-Off Switch: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-5.html
36) How to remove Torque and Tranny: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-5.html
37) Tie Rods and Rack Bushing Replacement: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-5.html
38) Wheel Size and Offset HELP!: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-6.html#post7364487
39) Ignition Switch Replacement: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-6.html
40) Air Intake Tube Alternative: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-6.html
41) Subwoofer Foam Surround Rebuild: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-6.html
42) Stuck Brake Rotor: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-6.html
43) Hood Heat Shield Replacement: http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-6.html
I'll Start this out:
Issue: 14 Pin Connector: Corrosion or broken wiring causing Various Electrical problems.
Fix: Always disconnect Battery when working with electrical. Use a small wire brush to clean the pins and the backs of the pins. this requires you to split the Halves. Be careful when splitting the halves as the pins may come out the Holder.
Pics: Here are some pics posted by Ender928. This is what you hope not to see when you split the halves. You'll need to repair wire here which will require some soldering. Also his Holder is cracked and needs to be replaced :( .
http://forums.pelicanparts.com/uploa...1301624274.jpg
http://forums.pelicanparts.com/uploa...1301624339.jpg
http://forums.pelicanparts.com/uploa...1301624390.jpg
Mrmerlin 05-06-2011 09:56 PM
before you find out the 14 pin is damaged inspect or clean or replace the ground strap at the battery.
HINT if you wash the car or its parked in the rain open the hatch and inspect the floor of the hatch,
if its wet then chances are very good the ground cable is corroded internal to the covering and should be replaced,
if there are funny elex issues haunting your ride
MPDano 05-08-2011 09:20 AM
Ground Points: Corrosion causing bad ground contact
Normal Fix: Use a small wire brush to clean the ground area as well as the round terminals
Here is a Pic of an S4 Ground Points and hopefully we can surface one for earlier models, which at that time I can add here.
http://forums.pelicanparts.com/uploa...1304871590.jpg
Dean_Fuller 05-08-2011 09:49 AM
Problem...
Rubber FUEL lines. They do not age well and are responsible for many fires where the car is a total loss.
FIX....
928Rus sells a fuel line replacement kit. Includes all hoses that need replacing with all necessary clamps as well.
This is one FIX that you need to do when you buy a car. Even when the hoses LOOK fine they are NOT. Rubber hoses do not last 25 plus years without degrading. Hose location and layout vary year to year so check with Roger...the set he sells has all hoses for all years so there will be some you don't need.
Landseer 05-08-2011 10:17 AM
OK, for early body cars see below. Some variation between CIS and Ljet and LH Jet euros. Note the voice-over for some points not shown on these diagrams.
http://forums.pelicanparts.com/uploa...1304875014.jpg
http://forums.pelicanparts.com/uploa...1304875030.jpg
Point 9 (9a and 9b) There are two crucial ground attachments on the 16V passenger side cam cover. They ground the engine electronics & the injector harness.
One is at the top of the "O" in the word Porsche cast into the cam cover --- and it may be covered-up by the emissions air injection valve/hose. The second attachment point on the cam cover is more visible and is closer to front of car.
Point 10 For later Euro cars, look for ground wires attached to the back of cam gear metal rear covers. These are for the "final stage ignition amplifiers"
Plexus928 05-08-2011 04:37 PM
Originally Posted by Dean_Fuller (Post 6009583)
Problem...
FIX....
And now that there are so many brand X import hoses on the market,make sure to replace with NAME brands,and graded fuel injection hose, first replacement when you buy the car, then maximum every 5 years to next replace, these hoses take big pressure, and nothing is forever.
(a pinhole with 60 pounds of pressue behind it will SPRAY a lot of fuel REAL fast,-they don't just drip!)
Landseer 05-09-2011 03:40 PM
Use 30 R9 fuel injection hose.
Do not use 30 R6.
2Quick4u928 05-10-2011 05:01 AM
Great details so far, not to meantioned the up-close pics :-)
Rupesy 06-06-2011 05:25 PM
'79 Headlights not going down
Just posting this in case someone is searching for solutions. My headlights work just fine and would go up, however, would not go down after turning off. I searched for solutions and didn't turn up anything that seem to help. I checked the normal stuff like fuses and relays. I looked around and found this connector to the headlight motor. When I unplugged everything, I found some serious corrosion. I just cleaned all the terminals and everything works as normal.
http://forums.pelicanparts.com/uploa...1307406302.jpg
http://forums.pelicanparts.com/uploa...1307406319.jpg
Normy 06-06-2011 06:23 PM
Normal Fix: Always disconnect Battery when working with electrical. Use a small wire brush to clean the pins and the backs of the pins. this requires you to split the Halves. Be careful when splitting the halves as the pins may come out the Holder.
That is a good one. Mine is without its cover, and it has a small amount of green corrosion.
N!
dcrasta 06-07-2011 09:29 AM
How can I get that rear interior panel off for cleaning ground #2 in the rear.
I have searched and a lot of information seems conflicting on removing this 30 year old fragile guaranteed 'Hugh will someone how break this' panel.
Help.
Landseer 06-07-2011 11:40 AM
Remove interior the quarter panel
Starts for me by removing by removing the rear seat.
Its quite a good puzzle, actually.
Hard to describe, step by step, from memory.
Mrmerlin 06-07-2011 11:54 AM
to get the #2 ground point ,
remove the RR cargo hold down use PB blaster on the screws,
then remove the 2 or 3 screws holding the rear edge and the ones along the floor of the hatch then gently bend the rear edge only far enough out to fit your hand to unscrew the 10mm bolt, it is either on the floor or on the wall just in front of the the taillight housing
qdac 06-07-2011 11:59 AM
I cleaned the #2 post in my 1981 US 5-speed last weekend without removing the entire quarter panel.
Steps:
  • Remove toolkit cover
  • Remove rear carpet
  • Disconnect ground strap
  • Remove the passenger-rear side luggage cover hook (2 screws)
  • Remove two trim screws from the quarter panel where it attaches to the body almost behind the toolkit cover
  • Remove the single screw that holds the panel down to the hatch area floor - on my car, this looked like a wiring bundle tie-down, but was also an attach point for the quarter panel
At this point, I was able to pop the quarter panel end out a couple of inches. This involved popping loose a couple of the trim posts that attach the panel below the rear window.
I could then fit my hand behind the panel through all of the soundproofing to get to the ground point bolt. I used a 10mm combination wrench and a LOT of time to remove the bolt.
Pull the ground wires back to the rear of the car to clean. I got lucky on the install and the bolt threaded properly the first time.
I took about an hour to do this. Turning the bolt with the wrench in these close quarters was extremely tedious and roughed up my hands quite a bit.
Good luck & be careful with this panel! I was rougher with it than I wanted to be but I managed not to break anything.
dcrasta 06-07-2011 01:32 PM
Yikes.. So this is definitely a saturday morning (cool air and all) project.
I think I will end up removing the seats. Besides, I might find some money or contraband (As I have yet to remove my rear seats in this car and I fear what may be lurking under them...)
Thanks for all the quick and helpful responses..
I now return you to your regularly scheduled forum thread..
Rupesy 06-19-2011 03:32 PM
'79 splash guards
I think this fix might be worthy of this post. My driver side splash guard in front of the tire that protects the headlight and horns was missing when I bought the car. I checked on buying new ones and they were a bit pricey. I remember seeing a post with this idea so I decided to give it a try. Fortunately I had the passenger side one for a pattern, however, that one is in pretty bad shape. I made a cardboard pattern first and used it to trace onto the storage container. Its a hair bigger than the original one so I could trim it back. I also decided not to mess with insulting foam around the edges so I wanted it tight. So far so good, but the true test will be next time it rains (tomorrow).
http://forums.pelicanparts.com/uploa...1308522560.jpg
http://forums.pelicanparts.com/uploa...1308522578.jpg
http://forums.pelicanparts.com/uploa...1308522673.jpg
http://forums.pelicanparts.com/uploa...1308522697.jpg
MPDano 06-19-2011 06:11 PM
Nice Mod! Put some Undercoating on that and it will look stock. Great work!
dcrasta 06-21-2011 07:12 AM
Broken Wheel Locks:
Scene : Your Porsche Factory Wheel locks (the ones that take a 'key' and resemble a 'cap' are stuck (lost key..)
Solution : Center punch the hell out of the key hole until the 'guts' fall out, then using a mangler (screwdriver) mangle it until it comes off.
Broken Wheel 'Nut':
Scene: Some neanderthal that doesn't understand how dis-similar metals disagree used a high torque Impact wrench (your fault) on your Aluminum wheel nuts, OR: Some special needs adult installed the aluminum wheel nuts on the car without anti-seize, and after the years that have passed watching your tires dry-rot you decide its time to remove the wheel, breaking the nut so short that there is not enough remaining to use a proper 'tool' ..The HOrrors!
Solution : Get a 17mm Arbored Hole saw (you will have to remove the centering drill bit). Looks like this http://ecx.images-amazon.com/images/...500_AA300_.jpg
Get 3 or 4 per wheel nut. Get some lubricating oil (light machine oil) and a heavy duty electric drill (put the recharging drill on the shelf this is real -drilling over here).
Carefully slide the hole saw into the hole. The goal is to erode the nut away without scarring the wheel, or damaging the stud. IF you are careful eventually you will erode the remainder of the nut away (use lots of lube, go carefully) to the point you can use a pick tool to get the metal remains out.
Use Eye protection. Metal shards blind people dumb enough not to wear protection everyday.
To prevent this particular form of self induced torture, use the correct antiseize on the ball cup end of the wheel nuts.
A little goes a long way.
MPDano 07-20-2011 07:54 AM
Issue: CIS, Hesitation on idle to slow throttle up. Leaning out.
Fix: Replaced faulty WUR and fixed vacuum issue on rear throttle body vac ports. I capped the T that runs vacuum to the Diverter and Decel Valve. Next step is to run a vac test to the Decel where I believe the Diaphragm is bad (vacuum leak).
http://forums.pelicanparts.com/uploa...1311136090.jpg
<iframe width="425" height="349" src="http://www.youtube.com/embed/kjSoLrxn61g" frameborder="0" allowfullscreen></iframe>
MPDano 07-20-2011 08:03 AM
Issue: AC does not work when car is in hot weather.
Fix: My Sensor located in the front left portion of the Fender, which is part of the circuit of the AC was not hooked up. I hooked it up and did some mods and some new 2-1/2" Heater Duct Hose. AC now works at any weather.
http://forums.pelicanparts.com/uploa...1310955048.jpg
http://forums.pelicanparts.com/uploa...1310955052.jpg
http://forums.pelicanparts.com/uploa...1310955057.jpg
http://forums.pelicanparts.com/uploa...1310955061.jpg
http://forums.pelicanparts.com/uploa...1310955066.jpg
http://forums.pelicanparts.com/uploa...1310955071.jpg
http://forums.pelicanparts.com/uploa...1310955075.jpg
http://forums.pelicanparts.com/uploa...1310955080.jpg
http://forums.pelicanparts.com/uploa...1310955103.jpg
http://forums.pelicanparts.com/uploa...1310955107.jpg
MPDano 07-20-2011 08:04 AM
http://forums.pelicanparts.com/uploa...1310955111.jpg
http://forums.pelicanparts.com/uploa...1310955116.jpg
http://forums.pelicanparts.com/uploa...1310955121.jpg
http://forums.pelicanparts.com/uploa...1310955126.jpg
http://forums.pelicanparts.com/uploa...1310955130.jpg
http://forums.pelicanparts.com/uploa...1310955134.jpg
http://forums.pelicanparts.com/uploa...1310955329.jpg
http://forums.pelicanparts.com/uploa...1310955334.jpg
http://forums.pelicanparts.com/uploa...1310955341.jpg
dcrasta 07-20-2011 10:38 AM
Issue : The headlight actuation rod pivot lever (wshew..sorry cant describe this) is retained by some small 'e' clips. If your car has had front end repair, or the headlight rod removed for any reason the retaining clips could be missing. If the clips are missing, the lever could become detached, and when you turn on the headlights instead of moving the light up could puncture the radiator.
Solution :
1-Inspect for lost clips as soon as you can
2-Replace any missing E-clips with factory replacements (or 5/16th replacements.)
3-Retrofit with self-locking clips [8mm]
8mm self-locking circlips from McMaster-Carr: McMaster-Carr
Part# 94824A400, mcmaster about $5 per pkg of ten. Fit fit good, and seem very secure.
They are just a black-oxide finish, so rust might be a problem in some areas. I would use white lithium or grease on them to retard rust.
153bigblock 08-04-2011 07:10 PM
Troubleshooting your Mercedes 722.xxx/G28 Auto box from the Mercedes Trans WSM (longish):
TROUBLE SHOOTING
TRANSMISSION SLIPS IN ALL GEARS
Incorrect modulating pressure. Modulating pressure control
valve or pressure relief valve is dirty or sticking. Vacuum line to
transmission vacuum capsule clogged or leaking. Working pressure
control valve dirty or sticking. Low working pressure. Defective
primary pump.
Transmission Slips When Starting Off In 1st Or 2nd (Reverse
Is Okay)
Band B-2 shift valve sticking. Band B-2 piston worn or
damaged. Band B-2 adjusted incorrectly or worn or damaged. Adjust
brake band B-2 by installing a longer thrust pin (if necessary). If
transmission operates properly with selector lever in "2", but not in
"3" or "D" position, one-way clutch may be slipping.
Transmission Slips In 2nd Gear Or Shifts From 1st To 3rd Gear
Check control valve B-1 for ease of operation. Replace valve
body (if necessary). Remove and install brake band piston B-1, check
sealing ring and replace (if necessary). Replace brake band B-1 and
thrust body for B-1. Command valve binding.
Transmission Slips During 2-3 Upshift Or Slips Initially,
Then Grabs Hold
Check modulating pressure and adjust (if necessary). Check
for temperature throttle installation (if equipped). Valve body worn
or damaged. Replace valve body (if necessary). Replace inner plates of
clutch K-1 or recondition clutch (if necessary). Check front cover
Teflon ring.
TRANSMISSION SLIPS DURING 3-4 UPSHIFT
Check and adjust modulating pressure. Governor damaged or
working pressure incorrect. Valve body worn or damaged. Replace valve
body (if necessary). Check Teflon rings supporting clutch K-2. Replace
inner plates of clutch K-2 or recondition clutch (if necessary).
INTERMITTENT NO 5TH GEAR
Check loose connections at throttle valve switch. Check for
poor or loose wiring connections between TCM and transmission. See
WIRING DIAGRAMS. Ensure proper TCM is installed.
NO 5TH GEAR OR TRANSMISSION SHIFTS TO 5TH UNDER LOAD
Check and repair vacuum line between intake manifold and
ignition control unit.
NO POSITIVE ENGAGEMENT IN REVERSE
AUTO TRANS DIAGNOSIS - 722 SERIES
Article Text (p. 8)
1996 Mercedes-Benz C220
Copyright © 1998 Mitchell Repair Information Company, LLC
Wednesday, January 26, 2000 12:03PM
Check plates and sealing rings on brake B-3 piston. Replace
if necessary.
HARSH ENGAGEMENT WHEN SHIFTING GEARS
Incorrect working pressure. Check and adjust modulating
pressure. Check vacuum line and connections for leaks. On vehicles
equipped with diesel engines, check vacuum control valve. Coolant
entering transmission oil cooler and contaminating transmission fluid.
Replace radiator. If necessary, replace all friction linings and/or
replace transmission.
HARSH ENGAGEMENT WHEN SELECTING "D" OR "R"
Idle speed too high. Check pressure receiving (pick-up)
piston in valve body for ease of operation and correct installation.
NOTE: Pressure pick-up requires a running period of approximately
2 seconds. Harsh engagement may occur during repeated shifts
between "N" and "D". If harshness takes place within 2
seconds, condition is considered normal.
HARSHNESS ON 4-3 DOWNSHIFT
Sealing ring on release end of band B-2 worn or damaged. Band
B-2 piston worn or damaged. Band B-2 thrust body damaged.
CHATTER DURING UPSHIFT
Valve body malfunction. Check and repair or replace valve
body.
WILL NOT UPSHIFT
Incorrect governor pressure. Defective governor assembly.
Check for stuck kickdown solenoid or for constant voltage to solenoid
caused by a defective fuel pump relay or sticking kickdown switch.
Valve body dirty or valves sticking. Repair or replace valve body.
UPSHIFTS AT HIGHER SPEEDS THAN SPECIFIED
Check pressure control cable engagement, condition and
adjustment. Check for stuck kickdown solenoid or for constant voltage
to solenoid caused by a defective fuel pump relay or sticking kickdown
switch. Check governor pressure. If regulator pressure is too low,
replace centrifugal governor. Ensure control pressure regulating valve
is operable.
UPSHIFTS AT LOWER SPEEDS THAN SPECIFIED
Article Text (p. 9)
adjustment. Check full throttle stop by accelerating engine and
ensuring throttle valve rests against full throttle stop. Readjust
throttle stop (if necessary). Check governor pressure. If governor
pressure is too high, replace centrifugal governor. Repair or replace
valve body.
NO KICKDOWN
Check throttle control and pressure control cable engagement,
condition and adjustment. Connect kickdown solenoid to battery and
check for proper operation. Replace solenoid (if necessary). Check
kickdown valve in valve body. Replace valve body (if necessary).
NO 4-3 OR 3-2 DOWNSHIFT
Control pressure cable out of adjustment. Leaking vacuum
hoses and/or connections. Ensure brake shaft piston is operable.
UNCONTROLLED DOWNSHIFTS OUTSIDE RANGE OF KICKDOWN SWITCH
Remove kickdown solenoid. Check "O" ring on kickdown solenoid
for damage. Check kickdown switch for sticking in pushed-in position.
Replace switch (if necessary). Check for kickdown solenoid stuck in
opened position. Replace kickdown solenoid (if necessary).
POOR ACCELERATION FROM STOPPED POSITION
Check stall speed. If stall speed is 400-700 RPM less than
specified value, one-way clutch in torque converter is slipping.
Replace torque converter (if necessary).
PARKING PAWL WILL NOT ENGAGE
Check rear engine mount. Replace engine mount (if necessary).
Check adjustment of selector rod. Adjust selector rod (if necessary).
SELECTOR LEVER DOES NOT ENGAGE IN "R" OR "P"
With engine running, clean centrifugal governor and ensure
correct operation. With engine not running, check operation of detent
piston in lower cover.
ENGINE WILL NOT START IN "P" OR "N" POSITION
Adjust shift rod and starter lock-out switch. Replace starter
lock-out switch (if necessary).
SMOKE IN EXHAUST (FLUID LOSS)
Diaphragm in vacuum control unit defective. Transmission oil
is being drawn from engine through vacuum line. Replace vacuum control
Article Text (p. 10)
unit (if necessary).
FLUID LOSS BETWEEN TORQUE CONVERTER & PRIMARY PUMP
Seal torque converter oil drain plug. If leak continues,
replace radial sealing ring and "O" ring on primary pump. Check
primary pump "O" ring groove for porosity. Replace primary pump (if
necessary).
HOWLING NOISE WHEN CHANGING GEARS (UNDER FULL LOAD)
Replace transmission oil filter.
HOWLING NOISE WHICH INCREASES AS ENGINE RPM INCREASES
Check primary pump and replace if necessary.
1ST GEAR & REVERSE TOO LOUD
Replace front planetary gear set. Reverse and 1st gear are
louder than forward (driving) gears due to gear reduction. If noise
seems too loud, or if in doubt, a similar vehicle should be used for
comparison.
3RD GEAR TOO LOUD
Replace rear planetary gear set.
RATTLING NOISE AT 1500 RPM IN ALL POSITIONS EXCEPT "R"
Brake B-3 plates are vibrating in transmission housing.
Replace brake B-3 plates, install damper spring and set release
clearance to minimum value.
LIGHT GRINDING NOISE IN "P" & "N" POSITIONS
This condition is normal if a "rolling" noise of front
planetary gear set is heard. If noise seems too loud, or if in doubt,
a similar vehicle should be used for comparison.
"ROLLING" NOISES WHEN DRIVING IN REVERSE
Disc brake B-3 release clearance too great. Adjust release
clearance to .06-.08" (1.5-2.0 mm) or replace disc brake plates.
Outside plate carrier of clutch K-1 contacts piston.
Primary Pump Bushing Loosens After A Short Operating Period -
Dowel pins for centering transmission to engine are not in place.
tychain99 08-08-2011 07:00 PM
are the headlights supposed to drop when the power to the car is off? I know when my car is turned off and the lights are up, i spin the dial to kill the lights, but they do not retract. If they are supposed to drop even with out the car on, i should check the connections you pointed out
MPDano 08-08-2011 07:35 PM
If the car is on and you have the lights on and up, when you turn the key off, just the lights will go off when you turn your headlight knob. This is normal.
Then with light switch off and the headlights up, turn the car on and the lights will drop back down.
924CarreraGTP 08-11-2011 03:18 AM
MPDano said I should post this to this thread, So here it is.
Porsche 928 electrical short tip!
Many times the overhead interior light can short and drain your battery. You can spend years checking the jumper, cleaning the grounds and pin connectors and never find it.
It is a common problem and you must remove the fuse to the overhead light.
Another thing, doing a draw test and pulling every fuse to find a short is tedious while standing on your head in the 928 floorboard. You are better off getting a clipboard, checking all systems and writing down the ones that don't work. Remove one fuse each day from the nonworking systems until you find the short. I narrowed mine down to the trunk latch, antenna and the interior light. The interior light was the short.
I hope this helps with your Shark ownership.
If you talk to enough people somebody will eventually tell you that the overhead lights short onto the body when the fixtures are rebulbed or due to the tabs bending. Its a common problem but so many people will tell you to check your jumper circuit and grounds only to leave you in the same place. My 928S now holds its battery charge for months on end.
dtool242 09-07-2011 07:46 AM
Not really so much a 'fix' as I am still sorting out what my problem is, and no pictures. Just some general tips for measuring transmission pressures from another thread I posted.
For all the test connections I used a 1/16 NPT to 1/4 tube fitting connector (Swagelok part number B-400-1-1) to which I connected 1/4 poly-flo tubing of sufficient length to route up through the passenger window connected to a gauge in my lap while sitting in the drivers seat.
Operating pressure:
The spec is 16.9 bar (245 psi) so I used a 0-300 psi gauge. This gauge is too small. When the car was idling in park or neutral the pressure is much higher than 300 psi. Luckily the gauge did not have a high peg so the needle wrapped around and was bouncing off the back side of the low peg. I'm guessing it was seeing ~350 psi. With the car in drive the gauge was bouncing between 240 and 250 psi with temporary drops when the car shifted gears and then right back up to the 240 - 250 psi.
Modulating pressure:
The manual tells you to drive at 140 kph (87 mph) to measure modulating pressure. I've seen where other people discuss that they measure and set with it at idle. When I measured I got ~64 psi (4.4 bar) whether it was in idle or driving up to about 70 mph.
Governor pressure:
This one you definately have to drive to measure the pressure as the pressure increases with speed of the car. This is the one that I am currently having problems with. Last night I installed a governor I got from Landseer and was still seeing low governor pressures. So according to the ATSG manual for the transmission http://avtopedia.ru/akpp/722-3%20722-4.pdf (pg 103) the next step for me is to check out the valve body.
One last tip:
I know I said above that I used poly-flo tubing, but DO NOT USE POLY-FLO TUBING! It will certainly stand up to the pressures but the problem is when measuring the modulating or governor pressures, the line will have to run perilously close to the exhaust. After driving a few miles around my neighborhood last night while checking the governor pressure, all of a sudden the pressure went to zero (had been riding 5 - 10 psi) and the car went to first gear and stayed there. I look in the rear view mirror to see a trail of fluid behind me. Fortunately I only had about a 1/4 mile to go to get back into the garage. Seems that the heat from the exhaust softened the hose and it separated from the swaged fitting.
MPDano 09-18-2011 04:41 PM
Sunroof Fix: Most of our Sunroofs fail due to old grease. Here is mine on my 83 928S. All parts were fine but just needed a good cleaning and some lube. I used Silicone Lube Spray.
This past Saturday I got the motivation to fix my Sunroof. It never worked properly since I bought the car. It was kinda open but trying to close it with the switch became impossible. I ended up having to use the little rubber motor clutch and spin it manually about 1000 times to get it to move 1/4".
Anyways took mega pics (of course) to show you how I successfully got my Sunroof to operate 100% and very smoothly.
The Instructions from this website got me motivated and helped a lot in getting me started in the right direction.
Sunroof
Open the Sunroof 3/4 of the way.
http://forums.pelicanparts.com/uploa...1316387573.jpg
Here are where the 3 screws a relocated (this holds the inner cover on)
http://forums.pelicanparts.com/uploa...1316387604.jpg
The 3 Screws (Manny, Moe and Jack)
http://forums.pelicanparts.com/uploa...1316387608.jpg
This is what those 3 screws connect to.
http://forums.pelicanparts.com/uploa...1316387613.jpg
This the Sunroof Tranny (as I call it) that connects to the Motor which on the other side of the screw pictured turns a gear that moves the toothed cable (which is inside a guide tube). That's a serious run-on sentence there boys and girls! The top arrow points to the electrical plug to the motor. I actually removed the Tranny and pushed the switch to make sure my Motor was nice and strong (which it was)
http://forums.pelicanparts.com/uploa...1316387618.jpg
These are the Four 8mm bolts that hold the Sunroof on. You'll find four more bolts on the opposite site.
http://forums.pelicanparts.com/uploa...1316387621.jpg
Eight bolts removed and sunroof removed and off.
http://forums.pelicanparts.com/uploa...1316387625.jpg
This is the Track you want to make sure is nice and clean. I used lots of Simple Green to get this nice and clean.
http://forums.pelicanparts.com/uploa...1316387629.jpg
http://forums.pelicanparts.com/uploa...1316387632.jpg
MPDano 09-18-2011 04:42 PM
These next two pics are the $$ Ticket. This is the toothed cable which moves inside the Guide Tube. Old 30 year old grease really slows this down and binds the whole system. I ended up using Silicone Lubricant (spray) to get these to move nice and smooth. I bought the Silicone Lube at Home Depot. I also used it on all the parts that touch or ride on each other. HUGE Difference!! I did a test when using the switch before the Lube and after. Absolutely awesome!
http://forums.pelicanparts.com/uploa...1316388324.jpg
http://forums.pelicanparts.com/uploa...1316388328.jpg
Clean these bad boys too. I used Brake Cleaner, the Lubed them with Silicone.
http://forums.pelicanparts.com/uploa...1316388332.jpg
http://forums.pelicanparts.com/uploa...1316388336.jpg
Here's the orientation of these pieces.
http://forums.pelicanparts.com/uploa...1316388340.jpg
http://forums.pelicanparts.com/uploa...1316388344.jpg
http://forums.pelicanparts.com/uploa...1316388348.jpg
Thes two bolts were fun to put back in, plus you need to make sure the washers that sit on the "other side" stay in place. Mine stayed in place with thick grease. Be patient here, you' also get your 6 pack ab's after this task.
**Update! Make sure to use Blue Locktite on these bolts since they may back out.
http://forums.pelicanparts.com/uploa...1316388359.jpg
This is a pic of the inside sunroof plate. You will need to get that all that vinyl/leather material back on the plate. I used the same adhesive I used on my Hood Liner.
http://forums.pelicanparts.com/uploa...1316388364.jpg
http://forums.pelicanparts.com/uploa...1316388368.jpg
Here's a couple pics of the adhesive in place. Your going to let it dry until the white becomes transparent then just press it on.
http://forums.pelicanparts.com/uploa...1316388932.jpg
http://forums.pelicanparts.com/uploa...1316388937.jpg
Here's a video of it all working. I LOVE MY SUNROOF!
<iframe width="640" height="480" src="http://www.youtube.com/embed/y1tKVAr8FzQ" frameborder="0" allowfullscreen></iframe>
MPDano 09-18-2011 04:46 PM
Here is the Silicone Lube I used:
http://www.maplin.co.uk/images/Full/N35FZ.jpg
Danglerb 09-18-2011 10:40 PM
Nice work Leo. Sometimes adjusting the interior roof panel can be a REAL PITA.
Harbor Freight sells a gadget for cleaning bike cables. A rubber sleeve clamps over the end of the cable with a hole you can squirt in cleaner that is forced down the cable (towel etc. at the other end to catch the mess), then spray in the lube.
I think I used Wurth HHS 2000, but garage door lube might work well too.
Landseer 09-19-2011 12:21 AM
Thanks for the sunroof description and pictures. And the whole thread, actually!
dcrasta 09-19-2011 07:59 AM
Awesome How to on the Sunroof. Great documentation and pics. Thanks!
MPDano 09-21-2011 06:59 PM
Issue: Low Alternator Output
Possible fix: Replaced Voltage Regulator. Huco Brand and Made in Germany. Purchased from Roger. Make sure all Grounds have been cleaned first.
I trust Roger so no question that this part would not be the issue if I wasn't getting the voltage I need after the install.
http://forums.pelicanparts.com/uploa...1316655849.jpg
http://forums.pelicanparts.com/uploa...1316655853.jpg
Here is the Remanufactured Alternator from Advance Auto. I already suspected the Voltage Regulator even before I put the Alt on as it didn't look new. I also pulled the Part Number off the old Voltage Regulator and it came back as one from China. Piece of Craaap! http://www.alibaba.com/product-gs/452389069/IP2700_12V_autmobile_electrical_voltage_regulator. html
http://forums.pelicanparts.com/uploa...1316655857.jpg
http://forums.pelicanparts.com/uploa...1316655861.jpg
I had to use an Impact Screwdriver to get the two screws off since they were on so tight. Worked like a charm.
http://forums.pelicanparts.com/uploa...1316655865.jpg
http://forums.pelicanparts.com/uploa...1316655869.jpg
Even this didn't look right as soon as I got the Regulator off, here is the before.
http://forums.pelicanparts.com/uploa...1316655873.jpg
Here is the after, I used a very very fine sandpaper to remove the black marks
http://forums.pelicanparts.com/uploa...1316655881.jpg
I used Blue Locktite on the supplied screws to make sure they didn't back out on me.
http://forums.pelicanparts.com/uploa...1316655886.jpg
Huco Voltage Regulator installed
http://forums.pelicanparts.com/uploa...1316656242.jpg
http://forums.pelicanparts.com/uploa...1316656246.jpg
This is the Volts just after starting. It's a Cold reading
http://forums.pelicanparts.com/uploa...1316656251.jpg
This is with the AC on and Headlights on. Car is still cold
http://forums.pelicanparts.com/uploa...1316656256.jpg
AC Off, Headlights On
http://forums.pelicanparts.com/uploa...1316656259.jpg
Headlights Off
http://forums.pelicanparts.com/uploa...1316656263.jpg
Warm reading. Nothing on
http://forums.pelicanparts.com/uploa...1316656267.jpg
After a 5 mile drive. nothing on
http://forums.pelicanparts.com/uploa...1316656271.jpg
This why you don't trust your Cluster Voltage Gauge. I got 13.5 volts on the jump post and this is what it shows inside.
http://forums.pelicanparts.com/uploa...1316656275.jpg
MPDano 09-24-2011 10:08 PM
Issue: Got Dim Instrument Panel Lights and you've cleaned all grounds and nada changed?
Fix: Remove Pod and then remove Cluster from Pod. Removed the three Large Refractors and three Small Refractors by popping them off with a small screwdriver. Use Brake Cleaner on a Tower to remove all the old Chrome Paint. Find some Chrome Tape from a Hobby Store and cover the areas where there used to be paint. Also put chrome tape on the small refractors.
Remove the three black connector covers and clean lightly the fingers with Brake Cleaner on a Q-Tip. I used an Xacto knife to gently scrape the fingers clean. Slightly tighten all screws and nuts holding the PCB (Printed Circuit Board).
Reassemble and test at night.
http://forums.pelicanparts.com/uploa...1316927213.jpg
http://forums.pelicanparts.com/uploa...1316927218.jpg
http://forums.pelicanparts.com/uploa...1316927221.jpg
http://forums.pelicanparts.com/uploa...1316927225.jpg
http://forums.pelicanparts.com/uploa...1316927230.jpg
http://forums.pelicanparts.com/uploa...1316927233.jpg
http://forums.pelicanparts.com/uploa...1316927238.jpg
http://forums.pelicanparts.com/uploa...1316927243.jpg
http://forums.pelicanparts.com/uploa...1316927250.jpg
http://forums.pelicanparts.com/uploa...1316927259.jpg
<iframe width="640" height="480" src="http://www.youtube.com/embed/jk59KSMSJB8" frameborder="0" allowfullscreen></iframe>
MPDano 09-24-2011 10:14 PM
Issue: Got old Brake Booster Vac Lines. Cracked or Rock Hard? Leaking due to this?
Fix: I picked up some 1/2" Heater Hose which is reinforced. Four feet of it to be exact. Picked up eight hose clamps while I was there. Used all my old hose as length templates.
Replaced hoses: Throttle Body to Y at Spider. Small piece from Y to Spider Body. Y to Coupler at Brake Booster. Small piece from Coupler to Brake Booster.
Tested with no leaks or collapsing.
http://forums.pelicanparts.com/uploa...1316927665.jpg
http://forums.pelicanparts.com/uploa...1316927668.jpg
http://forums.pelicanparts.com/uploa...1316927672.jpg
http://forums.pelicanparts.com/uploa...1316927676.jpg
http://forums.pelicanparts.com/uploa...1316927679.jpg
MPDano 09-28-2011 09:39 PM
Issue: A/C Clutch turn on then off. Electrical Buzz in HVAC Controller. System has no leaks and is 134a/R12 Full.
Possible Fix: My Ac worked fine up until 30 days ago. I had my local AC guy check and narrowed the issue to the HVAC Controller. Since I remember seeing a write up on replacing the internal relay, I thought I would give this a go.
I ended up buying all the pieces needed but found out that my internal relay is different. I ended up cleaning all the contact points with Brake Cleaner on a Towel to remove what I saw was oily substance all over the Circuit Board and then using my Dremel with soft brush at low speed on contact points as well.
My internal relay has a plastic removable cover, so I removed it and used a manual soft bristle brush and lightly brushed the contact points. Then I made sure to blow it out to ensure no bristles were left in the relay itself. Closed the relay back up and put the lower cover back to test it.
I started the car up and low and behold, I got arctic cold air again. I made sure to move the nicely newly installed slider back and forth and "NO" more buzzing noise. Somehow just cleaning it up nicely did the trick.
http://forums.pelicanparts.com/uploa...1317270892.jpg
The irreplaceable Relay
http://forums.pelicanparts.com/uploa...1317270895.jpg
Clean these contacts really good, you'll see yours won't be this shiny
http://forums.pelicanparts.com/uploa...1317270900.jpg
Clean these Fingers as well
http://forums.pelicanparts.com/uploa...1317270904.jpg
The top round thing is what the black plastic piece pivots on. You can remove the circlip and the pivot comes out revealing the metal pressure fingers which I also cleaned up. I also bent them slightly down more so it got nice contact with the Board.
http://forums.pelicanparts.com/uploa...1317270908.jpg
http://forums.pelicanparts.com/uploa...1317270913.jpg
Clean these Contacts as well.
http://forums.pelicanparts.com/uploa...1317270917.jpg
MPDano 09-28-2011 09:40 PM
On the underside of this round piece is a clip that holds this black plastic piece on, once the clip is off, you can clean the metal fingers on the underside. I also bent them down a little more to give them better contact pressure.
Last fingers to clean
