After Marker Oil Pressure Guage 16 V US Model
Hello any perhaps Informed Vested Members :
In would like to install a after market Non Porsche Oil Pressure Gauge and was wondering a suggested Place " Oil Galley " to draw Oil Pressure from ?
I read somewhere that the Sender Port has very High Oil Pressure ?
So ? was wondering if another spot might be a better Point to get a Oil Pressure Reading ?
If only the Sender port is able to be used do I need a very high reading Oil Pressure Gauge Perhaps ?
anyone has been down this road perhaps
for a 1980 US 928 Porsche
Thanks for any Input or suggestions
and note that I understand to alter a Factory Developed Gauge may void my everything .
Oil Pressure Guages
Old 06-10-2011, 09:51 AM
dtool242's Avatar
I don't think you need to worry about any factory warranty issues with a 30+ year old car.
Old 06-10-2011, 10:47 AM
Network Native
Danglerb's Avatar
Why not tap into the 2/6 bearing supply?
Old 06-11-2011, 02:03 AM
MPDano's Avatar
Here is a link to where I installed a Sandwich Plate under my Oil Filter to get the Oil Temp reading for my Temp Gauge. You could proably get a sensor to fit to the Plate and get your Pressure from there.
Mike, whats a 2/6 bearing supply?
Porsche 928 Forums dot com - View topic - Pics of my First 928 and Current Project
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 06-11-2011, 08:17 AM
Old 06-11-2011, 08:50 AM
MPDano's Avatar
Originally Posted by aluminum View Post
Nice Job on that Install MP !
By the way is that not a temp Gauge hook up on the Oil Pan up front just under the Water Pump area ( but on the the Oil Pan ) My 1980 US has a 3 wire plug in hook up at that spot .
" dtool242 "RE: any Warranty Issues of a 1980 >>
"and note that I understand to alter a Factory Developed Gauge may void my everything ."
That's a Dry sense of Humor >>ha ha Not a serious Point . If Your Serious ? .
However a 50 Year extended Porsche Factory Warranty sounds good to me ha ha .
Truth is I was just thinking that perhaps another Oil Pressure Point existed with perhaps simple access to get a Normal Oil Pressure reading .
Many Car's have High Pressure coming into the Filter from the Pump Etc but I believe many other points of Oil Pressure are in fact a lower amount >> say more in the 50 Lbs range or say 30 to 60 Lbs That's perhaps a more normal range . No doubt metered down somewhere by some port size or regulator perhaps.
That's your Oil Pressure Sensor. Also, on the Sandwich Plate, you can see 2 more blocked holes where you can add more sensors.
Old 06-11-2011, 10:52 AM
Network Native
Danglerb's Avatar
Top front of the oil pan is a oil LEVEL sensor, float and a switch.
I'm not a big fan of adding sensors and gauges, unless they have something important to tell me all the time.
OTOH for diagnostics I could go a little nuts with all kinds of sensors.
Old 06-11-2011, 01:18 PM
MPDano's Avatar
Oops, yes I was thinking of the Sensor next to the Oil Filter. Yes, Oil Level Sensor.
Oh BTW, your the reason I put the Oil Temp Sensor on there Mike
Old 06-11-2011, 03:37 PM
Old 06-11-2011, 05:45 PM
Old 06-12-2011, 08:28 AM
Network Native
Danglerb's Avatar
Aluminum is real easy to drill into, but the why and where still escapes me. What are you trying to accomplish?
Old 06-13-2011, 01:37 AM
MPDano's Avatar
I gave you an option which I believe is pretty easy. Any easier would have to be wireless, but that solution hasn't been invented yet
Old 06-13-2011, 05:19 AM
Drilling fo a Oil Pressure point is not a option for a " after Market Oil Pressure Gauge " for me .
Yes I understand the > "Sandwich Plate" adapter >>
was just think Perhaps a top Side Oil Pressure Point existed somewhere ? but I guess not .
So at some point I well just install a tee at the stock Pressure Sender to run a mechanical Oil Pressure Gauge . I shall leave the Drilling to Obama / Bush and the Middle East .
Old 06-13-2011, 06:49 AM
MPDano's Avatar
A "Tee?" You mean you are going to T off the electrical connection? How accurate will that be?
Old 06-13-2011, 07:03 AM
Architecture & Porsche's
Lindsay racing makes an intermedate temp/pressure port for $30 that installs between the oil pressure sender & the block: that'd be cheaper, easier. Sandwich adapters can be a pain.
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 06-13-2011, 08:08 AM
Old 06-13-2011, 01:17 PM
Well, an intermediate coupler with an 1/8" NPT on the side: extends the sender down about 1.5" to allow for the 1/8" port.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 06-13-2011, 01:18 PM
MPDano's Avatar
HA HA no ! " A Tee wherein "
you unscrew the pressure Sender and install a Tee > ( about a $ 2 / $3 fitting )
or " Brass Fitting / Junction " so that you can run another line in for a Mechanical Type Oil Pressure Gauge. IE : you screw in the Pressure Sender back into the Brass Fitting that well screw into the block and that same fitting well have another Point / Place to screw in a pressure line to the Gauge. Some (most ) are a small Plastic line that goes to the Gauge . Some are metal .
Didn't I hear a story of someone running something like this and it burst into the Interior. Could be very interesting having Hot Oil hit you while your driving
Old 06-13-2011, 01:42 PM
Network Native
Danglerb's Avatar
Think of the fun you will have comparing the two oil pressure readings, watching as both needles sit on the same value at anything above idle speed.
Old 06-13-2011, 05:28 PM
That would be the sandwich job >>
but you can remove my posts if you like
Old 06-14-2011, 07:07 AM
