Porsche Crest porsche 928 project
hey guys i have a 1978 porsche 928 project that i recently just got, the car did not come the starter, fuel regulators or air intake box, i need help putting the pazzle together. can some with a 78 928 send me a picture of their fuel regulators please so i can figure out where all the lines go.
Old 06-07-2011, 06:38 PM
perhaps this videos might help you guys help figure out what im looking for.
YouTube - ‪porsche 928 2nd video.3GP‬‏
YouTube - ‪1978 porsche 928‬‏
Old 06-07-2011, 06:45 PM
Pete R's Avatar
post a better pic of your engine. 78's have CIS injection. Do you mean the fuel distributor? Its a black octogon type thing that all the fuel line attach to.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 06-07-2011, 06:48 PM
if anyone can pipe in on this, is a 82 engine the same as his, I have the L type injection, if it is I will send you lots of good pics of my motor, I took a lot when trying to get mine to start.
Chris Ainsworth
Elmsdale, Nova Scotia.
Old 06-07-2011, 08:24 PM
Network Native
Danglerb's Avatar
78 is CIS a non electronic mechanical system of pressure regulation and continuous fuel flow. The 82 (US) is electronically regulated with injectors that open and close to meter the fuel rate. Not much in common that isn't pretty obvious.
BTW a CIS system thats been sitting even sitting apart pretty likely will need rebuilding before putting it back together. CIS does not like old fuel or any contamination, and the seals don't like being dried out.
Old 06-07-2011, 10:43 PM
928: Serial Enabler
Post a half dozen more pictures of the engine bay please.
84,85,86 928 cars
Old 06-08-2011, 03:38 AM
Porsche Crest
does anything go on top of the butterfly valve opening thing, or is it just the the air intake box?
Old 06-08-2011, 05:26 AM
MPDano's Avatar
Your good to go on this area. Just the Air Box sits over that. You just have a long screw that comes in from the top of the Body of the Intake Spider. You'll need to start snapping more pics in order for us to tell what is missing or not.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 06-08-2011, 05:40 AM
MPDano's Avatar
Old 06-08-2011, 05:41 AM
SharkHead
JhwShark's Avatar
You need to vacuum the butterfly flap and clean the top of the engine besides all the guidance you will be getting. I see nice little bits on it that I wouldn't want in the engine.
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 06-08-2011, 09:31 AM
thanks guys. i'll post more pictures when i get a chance. no im not sure what goes at the end of the hose.
Old 06-08-2011, 12:45 PM
i was trying to put in the starter i got from a 928 parts car. i have four wires that all go to the starter. the main big positive cable coming from the battery, a red big cable, not sure where it's coming from and two other small red cables. and does it motor which way the starter mounts? or will it spin the motor the wrong way if it's put in incorrect?
Old 06-08-2011, 12:49 PM
SharkHead
JhwShark's Avatar
The hose in the previous pic (next to the water fill) goes into the underside of the air-box (I believe you don't have).
I'll try to get back with starter info.
Old 06-08-2011, 01:25 PM
SharkHead
JhwShark's Avatar
The Big Red (comes from the ALT B+) and the main BAT cable join at the 30 post (BIG one top side of your pic).
There is/should be a black/yellow (the smallest gage) wire that attaches to 16 comes from 14 pin (pin 10), middle post.
There is a Yellow (with age it looks brown dirty red) larger wire that comes from14 pin connector (at pin 14) attaches at the lowest point.
You will be able to mount it with the solenoid under driver.
Old 06-08-2011, 01:34 PM
Network Native
Danglerb's Avatar
Seems like your in put it together and see if it runs mode, and this car needs take it apart, clean, and replace first.
Stranger things have happened, you just "might" get it to fire up, but just fire is more likely, or smoke, melting insulation on wires, then fire. After that its not a project anymore, just parts.
Old 06-08-2011, 03:59 PM
Recovering dismantler
neil30076's Avatar
+928 on that - the engine area is a mess - do as Danglerb says, or we will be seeing your next post as - parts car - fire damage!
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 06-08-2011, 04:17 PM
i plan on taking apart everything and cleaning after i find out whether it will run or not. this is the problem im dealing with now, i installed the starter and connect all the wires, after that i only got one fog light and the brake light working, did i wire the starter incorrect? or there is something else?
Old 06-08-2011, 06:43 PM
and im also trying to deal with this problem, it's could be the reason im not getting anything else electrical working. the guy put this "push button thing to avoid using the key to start the car which doesn't seem to be working.
Old 06-08-2011, 06:46 PM
neil30076's Avatar
Do you have experience troubleshooting complex auto wiring and FI systems? That looks like a major hack, and you need to get, read and understand the wiring diagrams.
We are here to help you, follow what we tell you and it may even run, eventually.
Get better pictures, it looks like the lug from the battery in the previous picture is not connected correctly - you are asking for a major electrical burn up if you don't connect everything right, and trying to find out if it will at least run is a big no-no.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 06-08-2011, 06:52 PM
no sir, i lack in trouble shooting wires. i've been reading wiring diagrams about these cars and it's been the hardest thing i've had to learn.
Old 06-08-2011, 07:09 PM
