GT DRIVER
porsche 928GT owners
hi....are there any 1991 porsche gt owners that i can contact for various tech info
Old 07-16-2011, 03:53 AM
Petie3rd
Mrmerlin's Avatar
what do you need to know just post it here
Old 07-16-2011, 05:14 AM
GT DRIVER
Hi... seeking information, photos or diagram over the air induction (vacuum) systems....also have aproblem that the car cuts out erractically when harsh braking.....
Old 07-16-2011, 10:35 PM
MPDano's Avatar
Have you gone through "all" the grounding points?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 07-16-2011, 11:11 PM
Network Native
Danglerb's Avatar
GT is 99% the same as same year S4, and 98% same as all 32v 928's, slightly different cams (close to the 85/86 cam profile), slightly different gear ratios, but otherwise pretty much the same for any driving issues.
Cutting out under harsh braking, my wild guess is that some wires are being moved and either shorting or ? Hard to even guess without more detail.
Old 07-16-2011, 11:12 PM
GT DRIVER
928 ground points
Hi....have you a diagram of all these grounding points or where can this be obtained...do u think that it can be relay related if they are not seated correctly....somebody indicated possible coil malfunction????
Old 07-17-2011, 08:37 AM
GT DRIVER
Is it possible in that the A/C guys had to work behind the main fuse box inside the car on the passesnger side (mine is a RHD) that they may have moved or crossed certin cables...what should i be looking for
Old 07-17-2011, 08:40 AM
Petie3rd
Mrmerlin's Avatar
well you need to start at the battery first,
make sure the connections are clean that they are tight,
and that the battery has a hold down,
the battery should not move in the well.
From there move to the hot post under the hood clean it as well as the 14 pin connector
NOTE do cleaning with battery disconnected
Next move to the CE panel
FIRST get a fuse relay chart at 928GT.com and on page 2 under tips and links print off a chart for your car.
Remove every fuse and clean the ends with an eraser then do the relays,
take a picture of the CE panel first so you can compare before and after,
any relay that has corroded pins should be opened and inspected for burning or corrosion,
this should get you pointed in the right direction
Old 07-17-2011, 09:04 AM
MPDano's Avatar
Grounding Points and 14 Pin Help Here.
**MOST Common 928 Issues AND Fixes**
Old 07-17-2011, 03:57 PM
GT DRIVER
Hi ...... thanks for the advice and tips.... went to website suggested and downloaded info... will try out and let u know......
Old 07-18-2011, 08:38 AM
i would not overlook the ground cable, as I have learned they can look fine, but underneath the black plastic wrap they can be bad.
you can put a neg ground jumper cable from the neg terminal on the battery directly to the ground point on the body.
Old 07-18-2011, 09:07 AM
