small leak on auto transmission
All:
I noticed a small leak on the garage floor
I crawled under the car and noticed that there was what appeared to be an oil/trans fliud leak on what looks like a valve or vacuum modulator.
Not sure what it is
It has some wires coming out of what looks like a sensor with a boot that covers the top of the sensor
This is where the leak is coming from
Not a lot of fluid but enough to tell the sensor? is leaking
Thanks for any advice
Provenceman
1987 s4 Diamond Blue
Auto Trans
Old 08-11-2011, 06:51 PM
MPDano's Avatar
Does it look like the part pictured in this thread?
Alternate Kick Down Relay?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 08-11-2011, 09:12 PM
sma;; oil leak on auto transmission
No not reallt
It is more cylindrical like a sensor with a boot on top of the and wires or hose
It is attached to the side of the transmission with a large knurled nut attaching it to the body of the trans
The fluid appears to be seeping from the top of the unit through the boot
Provenceman
Auto Trans
Old 08-12-2011, 07:07 AM
dtool242's Avatar
A picture would help immensly. I just got done rebuilding a trans, and I'm not sure what you are talking about. Like Dano, at first I thought you were talking about the K-D solenoid.
86 928S
98 Saab 900S Turbo
Old 08-12-2011, 07:14 AM
It's probably me not describing what it is very well
Will try and take a picture and get it posted
Appreciate the help
Provenceman
Auto Trans
Old 08-12-2011, 08:30 AM
The more that I look at the KD solenoid the more is does appear to be this
The rubber boot at the top looks the same with the wires coming out of the unit
That is where the fluid is leaking from
Hard to see when you do not have a lift and have to crawl under the vehicle
It's hidden behind the tube that is connected to the fluid reservoir
Provenceman
Auto Trans
Old 08-12-2011, 08:37 AM
Ok so if this is the little bugger, any suggestions on where to purchase a replacement
Provenceman
Auto Trans
Old 08-12-2011, 08:55 AM
