what type of ATF fluid to use
All:
Need to top off the ATF fluid in my 1987 928 getting a bunch of differing recommendations. So which is the correct ATF fluid to use. Understand the wrong fluid will ruin the seals Thanks as always Provenceman |
The reservior cap says Dexron 2. I use Castrol mult vehicle. It satisfies the need for Dexron. Next time I'm going to use whatever Mercedes uses for Dexron.
DON'T put import car trans fluid in it.:cool: |
Castrol Dexron 111 HUMMMM
Here's the link Which ATF to use now? - Rennlist Discussion Forums Mobil 1 ATF >>> Mobil 1 Synthetic ATF that sounds good to me for a good condition Auto Trans But if it has a bunch of miles humm not necessary Just a Dexron type is fine and just change it once a year > only about 8 QT's |
ATF fluid
Thanks very much for the quick response
Much appreciated Provenceman |
I have been using Dexrton 3/4 Its made by Valvoline its called Max life,
The same fluid is also used in the power steering |
| All times are GMT -8. The time now is 10:03 AM. |
