what type of ATF fluid to use
All:
Need to top off the ATF fluid in my 1987 928 getting a bunch of differing recommendations.
So which is the correct ATF fluid to use.
Understand the wrong fluid will ruin the seals
Thanks as always
Provenceman
Old 07-24-2011, 03:39 PM
Engineer of profanity
924CarreraGTP's Avatar
The reservior cap says Dexron 2. I use Castrol mult vehicle. It satisfies the need for Dexron. Next time I'm going to use whatever Mercedes uses for Dexron.
DON'T put import car trans fluid in it.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 07-24-2011, 04:25 PM
Castrol Dexron 111 HUMMMM
Here's the link
Which ATF to use now? - Rennlist Discussion Forums
Mobil 1 ATF >>> Mobil 1 Synthetic ATF that sounds good to me for a good condition Auto Trans
But if it has a bunch of miles humm not necessary
Just a Dexron type is fine and just change it once a year > only about 8 QT's
Old 07-24-2011, 06:19 PM
ATF fluid
Thanks very much for the quick response
Much appreciated
Provenceman
Old 07-24-2011, 06:59 PM
Petie3rd
Mrmerlin's Avatar
I have been using Dexrton 3/4 Its made by Valvoline its called Max life,
The same fluid is also used in the power steering
Old 07-24-2011, 08:04 PM
