Bay Area Patriot
TheStig's Avatar
Where the heck is the ATF reservoir?
Where's the ATF reservoir on my 1987 928S4...I'm only a 2 day old 928 owner....I looked in the manual but i still can't find it underneath the rear of the car.
Andy
1987 928 S4 - 3" Single Exhaust after cats
1999 Mercedes C280 Sport Package
2003 Mercedes ML350
Old 03-17-2002, 09:18 PM
It's on the right hand side of the transmission..only check it with the engine running, trans in Park and at normal operating temperature (or hot as it sometimes known as).
It's real difficult to see unless the car is on a hoist.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 03-17-2002, 09:36 PM
Senior Member
Hello
If you look from the rear at your car and go down onto groundlevel you will see the canister on the right rear beside the axlehousing and if you can see the level abouve the steel brace holding the plastic canister you have enough to maximum.
Refill is a bit harder and needs a shop lift.
Grüsse
Old 03-26-2002, 05:56 PM
