replace power seat switch
Hello everyone:
I am getting ready to replace a bad power seat switch on the passenger seat. Any tips or things I need to look out for or be aware of as far as the removal of the seat Disconnecting the main power cable to the seat, etc. Any help is most appreciated Thanks provenceman |
What year, type of seat? Usually, You do not need to remove the seat, unscrew the panel and pull it free, pull the plug on the back of the switch, remove the switch.
...what Neil said and if you got hands like a Jeweler, you can open it up and clean the contacts. Beware of the tiny itty bitty springs that attack you and leave the scene only to never be seen of again ;)
This is why you remove the seat and place it on a blanket and fix the switch ^^^^^^^ |
Stan, that's why I asked what year, seat type. If it's the early rocker switch, what I said applies, if it's the 4 way multi function, I agree with you.
power seat switch
Sorry my bad
1987 s4 with dual power seat switches From what you indicated looks i need to remove the seat Provenceman |
Done
Thanks |
Replaced the back rest power seat switch this past weekend and now everythng works great
Thanks everyone for your helpful commenst Regards |
| All times are GMT -8. The time now is 03:31 PM. |
