jdill
Dashboard change
well after searching hi and low ,i finally found a new dashboard on ebay without cracks,it just so happens it was done in vinyl and withstood the test of time, 30 yrs later it still looks brand new,i thought it would be a difficult job but it was not bad at all, turns out the dash is only held on by 4 screws, once all the bologna is out of the way,
79 928 euro -lint green/black leather 5 speed
Old 08-15-2011, 03:07 PM
jdill
Old 08-15-2011, 03:13 PM
Banned
Normy's Avatar
The term "WYAIT" comes to mind! How does your air conditioner work? The vacuum servos are ALWAYS a liability, and typically dead at this point. It would be good to refresh all of them, and buy a rebuilt climate control head while your at it. I just spent $1000 trying to get my AC working, and it is about.....50%. If the car has been in the garage it is cool. If it is in the sun for any time at all...I bake while driving. I should pull the dashboard, but this will likely take me a month or more, with my schedule, and I enjoy driving the car- My other car, a Ford Aerostar really is not exactly an inspiration toward spirited driving....
[It hauls plants and much very well!]
Good luck.
N!
jdill
my ac is great,, works perfectly but i did close off the line to heater core for the summer, the only issue i have is the cluster odometer,, and i have a small crack in the pod
Old 08-15-2011, 03:19 PM
jdill
i want to send the cluster to vdo for odometer gear,,, anyone have a suggestion? and recover the pod?? norm so far i have six hrs in the job its pretty simple
Old 08-15-2011, 03:22 PM
jdill
FTE LAUDERDALE SPPEDO wants 225 and i just got off the phone with no hollywood speedo and they are at 110, tommorow i will ship to cali.......i dont know what to do with the pod?
Old 08-15-2011, 03:40 PM
There are absolutely great instructions available on how to do the odometer drive gear yourself. Since you have the pod out already I would guess it would take no more than an hour to do it yourself. I have done it to 3 cars and it is no big deal....
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red)
Old 08-15-2011, 04:02 PM
How necessary was it to take seats out?
Old 08-15-2011, 04:17 PM
jdill
i am told the aftermarket gears are no good,, tom at 928 told me to send to vdo and i will get the original parts, they will also check the other guages for accuracy, some times somethings are better left to the professional...
Old 08-15-2011, 05:13 PM
jdill
the seats out of the way made things much easier, console screws are to close to seats,and the dash comes out a little hectic because of pod bracket, seats are only six screws each and the plug for power,there is very little room to work as it is,so i would recommend taking the five minutes to remove them
Old 08-15-2011, 05:20 PM
Recovering dismantler
neil30076's Avatar
Changing an odometer drive gear doesn't screw up anything, unless you do! Where do you think the odometer rebuilders get their parts? I have also rebuilt many, and none have since failed.
Oh, and accuracy of gauges on a 928 pod are a joke !
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 08-15-2011, 05:22 PM
jdill
i never said changing a gear screwed up anything, i am told the after market gears are not all good, i think the vdo speedometer shop gets their gears from the factory which is vdo, and they are not offerd to the public,, congrads on your success with your gearchanges,sorrt to hear your guages are not accurate,, maybe you should send them out to a profesional also
Old 08-15-2011, 05:31 PM
neil30076's Avatar
LOL. So your voltmeter, temp and others is accurate?
I don't doubt that a VDO shop can get parts from the factory for a 79 or 85; I suspect that Roger, Mark and others get from the same source .
I'll watch your post, and not respond again......
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 08-15-2011, 06:37 PM
Maleficio's Avatar
Sheesh........relax, fellas.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 08-15-2011, 06:41 PM
Petie3rd
Mrmerlin's Avatar
now is the time to replace the console pods 2 of them and you can test the defroster but probably leave it alone as it seldom leaks also replace the pod in the blower box and fit a new heater control valve and short hose with new parts the system will work as advertised
Old 08-15-2011, 07:17 PM
Network Native
Danglerb's Avatar
I can think of a few things on a 928 only a professional should do, fuel injection brains, wheel alignment, but plenty of stuff needs to be kept out of the hands of professionals and done slowly and carefully by the owner using methods worked out by other owners.
Number of factory VDO gears that have failed, all of them.
Number of aftermarket gears that have failed, none I know of.
Old 08-15-2011, 07:24 PM
Pete R's Avatar
nice find on the clean used used dash.. It looks great. The dashes do come out easy.. so do piston rings...once you get there.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 08-15-2011, 07:34 PM
jdill
[QUOTE=neil30076;6198188]LOL. So your voltmeter, temp and others is accurate?
I'll watch your post, and not respond again......[/QUOT
your response is not a problem neil but an authorized vdo repair shop does get their parts from the factory., im all for do yourself but im not a great big fan of aftermarket,,, i will use aftermarket when their is no other solution,but in this case i choose to go with oem,,,btw my other guages all work perfectly in this 85, in my experience the guages can be calibrated, the signal is usually the issue
Old 08-16-2011, 03:27 AM
jdill
how many years did it take for the vdo gear to fail? and the only reason to keep something out of the hands of a true proffesional is not having the ability to fund the repair or having nothing better to do,i appreciate your opinion but this recommendation has been given by voices that know better
Old 08-16-2011, 03:36 AM
jdill
thanx pete,, not bad for 150 plus the same to ship.. great improvement didnt want to deal with cluster after hearing horror stories ..these days professionals dont get alot of credit,,,i guess there are too many jokers calling themseves pros that will work for peanuts, and thats why getting something repaired correctly is hard to find, i doubt no hollywood speedo is going to let me down, now UPS on the other hand is my biggest concern,,,,
Old 08-16-2011, 03:50 AM
