Auto antenna broke at the carwash
Ok, i know, I'm a dumb@ss....i forgot o tun off the radio at the carwash and it broke off
![]() So i got a new one (some unknown brand but apart from it not being a "hirshmann" it looked exactly the same..go figure). Problem was i couldn't get the new one to work, it seemed like the motor wasn't doing anything. I don't remember if i read it here or on the Rennlist but i followed the procedure of swapping the aerial from the new one to the old and I'm glad to say, It worked !! I also found a procedure to fix the rear hatch latch (kept popping open while driving) so i loosened the the male part of the latch (on the hatch) and inserted a couple of washers under the rear part of the plate, that changed the angle enough so it grips better. I love these forums (both pelican and rennlist) they have saved me a lot of money in parts and repairs so far (yep, I'm dutch) ![]() Thanks a lot guy's..
Amsterdam Porsche 928 1979 euro BMW 320i 1998 Exec |
Excellent! Gonna guarantee that you awesome helps from users came from "this" Forum
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
A.J.
my antenna has a small curl to it, sometimes it is slow going up so i've tried straightening it by hand but its not quite perfect.
just the other day i was looking to try and find a small, non retracting antenna to swap it with. just like a black rubber, low profile one. I didnt have much luck, but i thought it would be a good swap, looks and function wise
1980 auto- cashmere beige 1984 auto- black on black |
A.J.
did you have any idea what car to take the antenna off of? i wanted to look, but wasn't sure what kind to put on.
I was looking at universal fm antenna's at a local car shop and if i was going too buy one i would have gone with the shortest thick, black (rubber?) antenna (about 25cm long, 1.5cm at the base tapered to .5cm at the top).
A.J.
That sounds good, but you would need one that mounts at a side angle, not front to back taper if you know what i mean. I saw one today on a prius that looked like something i would want, but I need to find one that will mount correctly, and cover the existing hole
I replaced mine with this. Works great, flexible and cheap. It was like $15 at some pepautomegaworld place. They had like 10 universal ones to choose from. The base has a rotatable bottom that allows it to be mounted almost any angle.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car Last edited by Pete R; 09-23-2011 at 05:36 PM.. |
On my Euro, I bondo'd the hole up and put a Shark Fin Satellite Antenna on the Center Hatch. On the "S," I went to a Stock Hirschman but in Black.
![]() ![]() I like Pete's choice too.
I actually wanted one up on the hatch like that, but then ran out of ambition to fish the wire to where it need to be from up there.. and $15 sealed the deal
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Come to think of it. It was a serious Pain in the A$# to get the wiring up there.
That looks like the one i was looking at, that does look pretty good.
