"LEOS928" get prepped for Painting. Finally!!
Ok fellas and gals, I finally got the better halfs approval to get my 928 painted. Already chose the color (Gunsmoke Mettalic) from the Kustomshop line of their new line "Hot Rod Flatz."
Hot Rod Flatz ![]() I am taking every spare minute I can this weekend to start pulling parts off. I already spoke to the Painter Shop about the project and felt very confident on his work. I got motivated in doing a flat color since I saw the Lamborghini Reventon done in the same flat color I am painting mine. And yes! PICS will follow
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Good luck. I hope it works out the way you hope. The few flat 928's I've seen don't look that great. I think Satin would look pretty good but I guess we wont know until someone tries it. BTW, I thought your car was already flat black?
1984 928's w/ 5 speed Smoked Quartz Metalic 1982 928's Turbo w/ 5 Speed Platinum Metalic 1978 Euro Widebody w/ 5 speed Guards Red |
928: Serial Enabler
No car ever was more worthy. Nice save. Good choice.
Very excited for you Dano. Is this the last big step to completion? Gunar
Thanks for the kind words guys! I just finished getting both bumpers, and both front fenders off. The hard part is done. Just gotta pull trim and the S4 Wing and should be dropping the 928 next week sometime. Will upload some pics in the morning, I am beat. Damn all those 8mm nuts.
Network Native
Get er done, Leo.
Petie3rd
Dano dont forget if there is/are any cracks in the painted surface of the PU covers then they should be stripped down to the surface with a media blaster with walnut shells.
If the painter tries to feather out scratches or cracks they will come back in a few weeks especially with the dark color. I have seen this happen more times than you can imagine. I know it sounds like a lot more work but its better than repainting again after you see the cracks emerging. Also that zinc chromating should be applied to all of the aluminum metal on the car prior to the epoxy coat if your going to bare metal. (We sprayed my car complete with the zinc for and even coat) The aluminum has to be prepared differently or the top coats wont stick. When i repainted my 79 we stripped it, alodined it, zinc chromated it , 2 coats of epoxy with a dry block sand then, 2 more coats with a wet sand then , a Glassurit base/clearcoat., Both PU covers were blasted with shells , and 2 coats of the epoxy sealer with flex agent then, flex added to the paint/clear for the PU covers Its a whole lotta work but the better the prep the longer the top coat will last, good luck
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats Last edited by Mrmerlin; 09-19-2010 at 05:04 AM.. |
Put on another coat -
Man - No wonder a factory quality Porsche repaint is so expensive when done correctly. Painting seemed much simpler before all the modern exotic panel materials were being used. I remember one of my earliest efforts as a teenager to help repaint a friend’s car - the logic for long term quality was pretty simple. If there were any sanding scuffs and you had paint left over, you just put on another coat.
Michael Last edited by JK McDonald; 09-19-2010 at 05:57 AM.. |
SharkHead
Great news! Looking forward to the pic's.
'79 928, 85k Opal Metallic '99 BMW 540i, 97k Titanium '72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga |
As promised. Some pics from Sat and Sun.
The Paint Project Dismantle begins: ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Are you jambing the car? Painting the jambs, inside of hood, hatch?
I'm looking forward to seeing pics. I started Garrett's in May and I'm just now ready to paint something. |
928: Serial Enabler
The more close-ups you can shoot of the body seam / connection areas, and post them up, the better. It helps to see how it goes together when planning similar projects. Thanks, Good Luck with the painting (both of you)
Petie3rd
now is a good time to scrub all of the under panel parts this will remove as much dust and dirt that can be blown into the new paint
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
NO substitute
Congrats LEO, this is awesome, looking very forward to seeing the progress here.
Love the idea of a flat/satin finish, gonna look sinister on that Shark, for sure... |
European Shark
Wow, I'm really looking forward to finally seeing your car finished. Although it did look sinister in the flat, flat primer black..
1978 Porsche 928 Euro 5spd. Silver metallic/Black 1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed* Owning a 928 is risky business - but sometimes you just gotta say "what the fudge". |
I think there is alwasy something that needs to be done on our cars. I guess the answer to your question is no. I still have to drop the transaxle and fix a seal. I got lot's of plans but little money.
The Jambs and other interior areas have already been painted Black using the rattle can. I scuffed, primer, then used Duplicolor paint. I know it's not the best way but it's good enough for me.
Great idea. Will do on subsequent pics.
Absolutely, I just ran out of free time as Sunday was my 3 year olds day at Legoland. I will also take your earlier suggestions to the Painter. I really appreciate it.
