Architecture & Porsche's
928-Electrical-knowledgeable: where's "Plug X" by the fuse panel?
I have no idea where this is: my only reference was to the bottom (of the fuse panel) alphabetical wiring plugs, but it stops at W...last time I recited the alphabet, X followed W..:/
85-86 LH Jetronic car. Thanks! Mark ![]()
Porsche Club Racing National Scrutineer '89 Andial 951 '82 928R '74 911 RSR 3.6 |
Petie3rd
IIRC its in the center of the panel NOTE is only a 4 pin connector,
the rest of the connectors are 5 pin per row
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
"your strength gives me strength" (The Mummy, as stated by the wee thief).
Can you tell me where on this picture to look? I'm not seeing it. :/ ![]() ![]()
Old post, but so are these cars also.
I have trying to find this mystery plug X, but no result. -85 euro manual, with LH Jetronic, but same electric panel as in above pics |
i see in the OP pics that the page in the manual was printed in 84 - so it may not apply to your later car...?? - the 84 CE panels have the old style fuses
84 928 S - SOLD 2012 Cayenne S |
Are you looking for the plug that goes to the alarm? If so it is located above the glove box, at least in left hand drive cars. I see yours is a euro, and don't know your locations so don't know if you are right or left hand drive.
I am from Finland
That reference is for the 84 Euro, which was the first LH-Jet model.
What are you looking for? are you trying to determine if you are getting power to the LH computer? on the LH plug 5 should be ground, so verify that it has continuity to the chassis. LH Pin 9 shoul receive power from pin W23 on the CE panel. W23 is connected to pin 87 of the LH Realy. |
928-Electrics Guy
Plug X does not exist after 1984. The whole CE panel was redesigned in 1985, more fuses, more relays and bigger plugs with more connections on each.
Alan
1994 928 GTS Black/Black Manual |
