what is this
i found a small tank and hose they arent connected to anything and i dont know what they are does anyone else know also im trying to replace my fuel hoses from my pump to my engine before i put in my new pump and filter but i need to know how long and what dimension hoses i need all for my 1978 928
Old 10-30-2011, 06:59 PM
MPDano's Avatar
That looks like a vent line but not real sure. Maybe to the Carbon Canister? Anyways, most of your fuel line is hard lines. You can see the short fuel hoses which are connected to those two right angle hard lines at the bottom of your picture. I'm pretty sure those fuel line dimension and type are covered in the Fixes Topic. If it's not, it sure needs to be.
Also, the tank is the Windshield Wiper Fluid, the part that is broken off is the Filler Spout.
**MOST Common 928 Issues AND Fixes**
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 10-30-2011, 07:38 PM
Heater cut off valve??
Old 10-30-2011, 11:14 PM
Recovering dismantler
neil30076's Avatar
NO, part of the air pump system, feeds cold air back to the cat converter.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 10-31-2011, 08:10 AM
MPDano's Avatar
I think he needs to start putting arrows on his pics as the answers are all over the place
Old 10-31-2011, 08:15 AM
Not sure what Your talking But
I believe there is a windshield washer Container That go's there That's Missing
Humm wonder if I am Right is this a contest or sorts lol
Old 10-31-2011, 06:13 PM
Sitting at the bottom of the pic is part of the air pump plumbing.
At the top middle is a missing washer fluid reservoir that is missing. Looks like it broke off.
Old 10-31-2011, 06:49 PM
I Agree lol you get second Prize however I came up with the right answer first lol
however i will share my prize with you ha ha .
Most of the Reservoirs I see are missing the Cap > then the washer fluid sloshes out on to the motor and settles on the spark plugs making it look like a water / Anti Freeze leak coming from the motor > However it is just washer fluid.
Old 11-01-2011, 09:58 AM
jim ross's Avatar
Dano is right..as you are aluminum..the broken filler top is for windshield washer fluid and the cut off hose if for the carbon canister. I know this cause i removed all that crap! do yourself a favor and remove it too..dead wieght and surley clogged and useless.but connect the hose from the canister to the return line to gas tank or youll be smellin fumes.
Old 11-01-2011, 10:06 AM
MPDano's Avatar
Negatory Ghost Rider See Post #2
I'm all about sharing too, so everyone gets a piece of the prize
Old 11-01-2011, 10:14 AM
jim ross's Avatar
so i was right but late??
Old 11-01-2011, 10:34 AM
MPDano's Avatar
Not U, Mr. Aluminum
Old 11-01-2011, 10:53 AM
1978 928 - 9288200072
I went out and took some pictures of my car (1978) to see where the hoses go. You can see that the broken off piece is the filler cap. You cannot see the hoses because the filler is in the way.
Here is a picture of the hoses (there are three of them) the best I could get with my camera. All three go through the wheel well to where the charcoal canister is located. The hose on the left which is cut in your photo actually goes into the side of the air cleaner (see second picture). The hose on the right side in my car comes out about 8 inches and is not attached to anything. The center hose goes towards the back (I can't see where it goes to) so I expect it goes to the fuel tank.
I don't know if the three hoses are correct on my car, but this info might help you a bit.
Rick
1978 928 - 5 speed - no sunroof - Copper Brown Metallic - Cork Interior
Old 11-01-2011, 04:32 PM
928Shane's Avatar
My 78 is the same as onestar's except the brokem bottleneck. two hoses one open one going to the air cleaner.
Old 11-01-2011, 05:07 PM
ok thx guys i was just making sure i wasnt missing a part for that hose i guess i can make something for the washer fluid thx for the help
Old 11-02-2011, 12:50 AM
