Oil Change
What is the recommended mileage between oil changes? My '88 has 76,000 miles and climbing. I hardly even drive my other car anymore.
It all depends on your driving, Hi way, City, etc. Some change every 3K, but 5K or 6K might be fine.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Kinda up to the owner (you). 3K using Dino Oil and 10K using Synthetic Oil. I use Synth in all my Cars and change about every 5 or 6K. And no, none of my 928's leak Oil due to using Synthetic Oil. Royal Purple 15/40 for me.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
1982 928S
RE: oil change
Leo, how cheveron 15/40 that you buy from costco 3 in a case, i was told its good for all year around, and i been use in it in my boats for years, but not in my porsche. last oil change was done by valvoline lube station. Ed.
Yes I make sure to use synthetic oil, I will take it in soon in that case. Thanks for the info.
Do it yourself. Especially most Drive thru Oil Shops don't have the correct Oil Filter. Get the correct one from here (Pelican) or 928 Intl. I don't trust those Oil Shops as I've heard horror stories of them forgetting to refilling the oil. Not good.
Network Native
Things to mess up in a 928 oil change;
Not using the correct amount, which is something like 8.5 qts? (8 with a filter, run and then top up). Buggering the drain plug threads. Failing to replace the crush washer on the drain plug. Using too thin of an oil, like a 5w something. Wrong oil filter. Failure to notice some unrelated problem. |
Engineer of profanity
Castrol 20W50! I dropped that bomb.
1970 Porsche 911T Black 1990 Porsche 944 S2 Red on cashmere 1984 Porsche 928S Euro ROW GP white on black |
1982 928S
928 Newbie
I use shell rotella 15w40 or Castrol 20w50.
Oil change varies due to driving conditions . One way to estimate when its time is take a look at the oil on the stick. It starts to turn dark brown or smell like gasoline its time to go. I usually can get about 5k from my oil before its starts looking bad. Change the filter on every change. New crush washer. I needed 9 quarts for my car. |
