Ignition Question
I have a 1982 928. When I try to start the car the key doesn't spring back after starting, I have to do it manually. But also half the time the starter doesn't disengage. My question is do I need a new key & tumbler or the electronic part that attaches to it, or both.
Old 12-06-2011, 12:12 PM
928 Newbie
dcrasta's Avatar
Try taking it out (ignition switch) and cleaning the switch. Dry ease works on the key section (dry graphite lube). You can try spraying it out with contact cleaner and de-oxit.
If you need to replace it, try to get the electrical section from a used car, or a real porsche part. Stay away from Ebay/chinese parts. Fires have happened.
Old 12-06-2011, 12:27 PM
Recovering dismantler
neil30076's Avatar
Common problem - you need only the switch part ( 928.613.017.00 ) that is on the end of the assembly. Make sure you get a genuine porsche part, not the cheap chinese knock offs that are on ebay!
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 12-06-2011, 12:28 PM
928 Newbie
dcrasta's Avatar
Snap - 7 on Ebay right now..
Porsche Electrical Portion of Ignition Switch fits 1984-98 911 New | eBay
Old 12-06-2011, 12:29 PM
neil30076's Avatar
Originally Posted by dcrasta View Post
That one will work....
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 12-06-2011, 12:33 PM
