Finally got some time to work on the 928.
Well, i disappeared for a while. Im back, for the time being, and i grasped some time to put into the 928.
What im doing- Pulling the tranny.and im stuck at one of the steps. Im dealing with pulling the emergency cable out of the back of the rear brakes. I dont know how to get it out. Do i have to pull the rotor? Thanks in advance. Hadn't started it in 3 months, and this is the only day since ive been off thats been decent to work in. Turned the key, cranked over a few times, and busted off. Thanks in advance. |
You don't.
Disconnect at the pull handle. Use vice grips, then, to wiggle/twist it out from body. The whole cable then goes with the rear axle and wheels. |
Oh, ok. Then i just feed it back through when im done. Sounds good. I would have had it changed today if i knew that.. The guide i have (I cant remember who gave it to me) just said "Gently tug on the fitting in the wheel well to remove the cable housing" I thought it meant disconnect it from the brakes themselves.
Thanks for that bit of info. |
| All times are GMT -8. The time now is 01:28 AM. |
