928-recent virgin
86 sunroof leak
any tricks on getting the sunroof tight. when i bought this car, it did not leak but since ive used it off and on, it leaks. Can i moisten the seals with anything?
1986 928s black on black 1971 Ford Mustang Conv |
I think there was mention of a drain that seems to clog up. Couldn't hurt to rub a little silicone spray on the seals either. Knock on Wood, it's rainy here in SoCal and no leaks so far.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Petie3rd
since you have a black car i will venture a guess that your rear drip panel inside the sunroof enclosure is broken.
(Now is also a good time to swap out the old seals for fresh on the sunroof) Only solution is to remove the sunroof , then remove the broken tray then install a new part, also inspect the drains use a piece of weed wacker line to clear the lines not compressed air
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Yes, this is what I heard somewhere. Is this only accessed if you remove the Sunroof?
You can get to front drain holes without removing the sun roof. I can'r recall about the back ones.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
Petie3rd
the roof has to come out to get to the rear drains..
BUT its usually the drip tray thats failed
Network Native
Where is it getting wet? May not be the sun roof at all. If the passenger floor board is wet it could be the blower box seal. If it is dripping at the aft edge of the headliner it could be the hatch seal.
A common Problem with the drivers side front drain is having the drain tube crushed when the factory installed the vacuum reservoir. This was the case with my 85. Have to remove the wheel well liner, then vac reservoir and trim the crushed end off the tube to fix it. Easy enough to do though. |
