wood fuse panel door
can anyone show me a pic of the screws or bolts, washers, or whatever those crazy Germans used to hold the small piece of wood that the fuse panel door sits on.
Mine did not come with it, and I don't see anything on the parts disc. thanks,
wood fuse panel
u have only the top piece, its two wood boards that are put together with the carpet and straps,and two screws that are put through two little wood scraps that mount to the fuse/relay straps "metal" that hold it in....if that makes any since? i can send u pics tomorrow of what all the pieces look like and how they connect,very simple concept
jdill
no thats the bottom the door closes on you just need two washers and two phillips head screws i think they are m6 about 1.5 inches long thats all thats missing
Yup, just a couple Phillips head screws and washers.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
can anyone post a pic, or have a part #
When did the changeover to studs happen? In my 89, this board slips over two M6 studs that are on a bracket under the CE panel. And you fasten it down with M6 nuts and flat washers. I can't find any indication of the hardware for any year in PET. PET does show a changeover in that board in 84.
I always imagined cutting this board had to be the lowliest job in the plant. Plywood. |
jdill
do you have a work shop manual? 10.11 engine removal pic there shows the board
928: Serial Enabler
Ok.
84,85,86 928 cars |
European Shark
1978 Porsche 928 Euro 5spd. Silver metallic/Black 1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed* Owning a 928 is risky business - but sometimes you just gotta say "what the fudge". |
thanks!
Landseer, you must be an engineer or surveyor maybe? I see you have an old HP 10c series calculator on your desk. It looks like an 11c? I use a 12c for real estate appraisal everyday. Gotta love reverse polish notation.
89 928 S4 5spd project 81 928 5 spd gone 84 928S 5 spd euro gone 71 911T gone 83 944 gone |
928: Serial Enabler
Sorta. Chem E converted to procurement. (speaking of which, say more about that car you have for sale...)
Its a 12C. Relearning it. My progression was 35 - 45 - 67 - 41C - 41CV - 11C, now, 12C + 35C Meanwhile, proficiency has plunged.
84,85,86 928 cars |
Like the other ones the 12c is easy once you get you basic keystrokes down. Here is the add I have going. FS 1981 928 5spd Shoot me a pm if you have any questions
You guys make fun of Porsche for using plywood to cover the CE board, but can you think of any other non-conductive material besides wood that would work as well, last as long and be as affordable?
1982 Porsche 928, Auto, 4.5 http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945 |
Sure, 3 letters. MDF. Also lots vinyl plastics which if made in bulk would be less expensive
Yeah, but regular wood has more personality. ![]() I wonder if I made some fancy hardwood CE paneling for the 928, would you guys buy it?
no, got very busy , sorry man! its plywood,mines a 3 piece unit for 80' u can make your own if u can build a speaker box....the small board is your bottom,a much bigger top and a small side piece that has a snap on it, to connect to your rocker panel,to hide the elect. devices, dont have pics yet,though they do have the bolts to connect to the floor boards but its only two...the relay/fuse panel sits in the floor with two plastic "fingers" at the bottom that slide into two holes...top bolts go into top slots of panel,dont tighten too hard! loose fit,but firm.
Hi !
Could someone post pics of both parts of this wood cover please ? I don't have it and I'll need to make one. If possible, with some measurements. (thick, length, width) Thank you very much ! |
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Any pics ?
Thanks ! |
