newold928's Avatar
Can't find parts for German dash
I have not seen any parts for my Car my speedo and cruise control doesn't work it's metric and im Hesitant about using non metric parts
Old 01-15-2012, 08:33 AM
Not sure what you are referring to? What on the dash doesn't work? The cruise control is a separate system.
Old 01-15-2012, 08:44 AM
newold928's Avatar
speedometer, temp gauge, amp meter, oil pressure. this is my first Porsche and i am not sure of what is broken?? should i just get a new pod. I want to order a service manual but they cover several years not just mine. Basically i just want to know if parts are interchangeable
Old 01-15-2012, 08:54 AM
19psi's Avatar
All those gauges didn't just fail. It's more than likely a simple wiring problem such as a bad ground. Pull the pod and start looking for the obvious before wasting lots of money on parts you don't need.
Use Google to search for the manual in PDF format and download it.
George in Indiana
928 Weissach #153
Cayenne S
Old 01-15-2012, 09:01 AM
MPDano's Avatar
Fingers on the PCB most likely. Read here on the Dim Instrument Panel Fix.
**MOST Common 928 Issues AND Fixes**
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 01-15-2012, 09:22 AM
newold928's Avatar
Will do thank you for your help. I had a similar problem with my corvette ( i know ill be back again)
Old 01-15-2012, 10:02 AM
newold928's Avatar
Porsche Crest
OK found the problem with the speedometer busted gear from the drive motor to the numerical gear drive.( jack shaft gear). The gauge finger's were dirty now im just going to replace all the bulb's while im here
since im new to the game is it common for the 928's to have an aluminum front end?
it's not fiber glass sound's like Metal
Old 01-15-2012, 01:30 PM
MPDano's Avatar
All metal body, aluminum and steel. Just use a magnet to id them. There no fiberglass body parts on the 928.
Old 01-15-2012, 01:41 PM
Engineer of profanity
924CarreraGTP's Avatar
A lot of times the white connectors that plug into the guage cluster come loose. It usually ends in one side of your guages not working at all, but the other side working fine. Sometimes the contacts that slide into the connectors are just dirty. I've read cleaning them with a pencil eraser is the way to go.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 01-15-2012, 04:33 PM
Front and rear bumper covers are not metal
Old 01-15-2012, 05:02 PM
Network Native
Danglerb's Avatar
Welcome to the forum.
Take it slow and easy, first up tell us about you and your car;
We can guess its a non US Porsche 928, what are the details like year and model and if you want to know about options post the vin too.
About what is your location, so local people can help out and tell you about events, in fact its good to put this info in your profile or a sig line along with the above.
We are nuts for pictures, so post a few.
Thats not metric, its German, Brems are Brakes, Wasser is the stuff you drink when there isn't any beer.
Roger at Home - 928's R Us Porsche Parts Store stocks the correct odometer gear.
Old 01-15-2012, 06:39 PM
newold928's Avatar
I have a 1979 vin 928 910 1325 auto( i know)
I know absolutely Nothing about this car but i'am learning quickly.
This is what i found do not work correctly
speedometer (Tested- works outside of car)
cruse control is Kaput
windows are noisy slow and sun roof too.
Idle bounces all over the place(never over 1k)
Brakes are hard
steering hard
P.O Hacked in a rear spoiler and the chin spoiler that fell off in pieces on 85
No heat
wont get hot
P.O put in remote switch for A/C
Only one wiper working
I have the original rims with it 16's
I live in the Salisbury are of N.C
Old 01-16-2012, 12:36 PM
txhokie4life's Avatar
most likely the fingers on your mylar aren't making contact.
I'm pretty sure your speedo is voltage driven not mechanical
I do love the German dash - almost tempted to swap you :-)
mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 01-16-2012, 02:53 PM
Network Native
Danglerb's Avatar
Brakes are hard
steering hard
No heat
wont get hot
Nice looking car. US and Euro are the same pretty much for 79, different names on some indicators, but mechanically the same.
Speedo and cruise require the same signal from a rear sensor, often the issue is a 4 pin connector in the spare tire well.
Wow, your sun roof works, congrats. All the switches are worked hard to directly drive the motors, need either cleaning or replacing. See Leo's write up on cleaning the sunroof tracks.
Brakes and steering on a 928 take more force than a no feel power steering car, you get so you prefer it.
Leave the spoiler off, better to have the clean lines and its mostly looks below 125.
Heater valves tend to fail and get disconnected. Replace the hoses etc during a top end refresh.
Flush the radiator, and put in a new thermostat and related seats and seals.
Fixing PO mistakes is your new main hobby, back to stock removes many issues.
Wiper is likely a simple linkage issue, but rebuilding the wiper system results in a much nicer quieter system.
I think original rims were 15".
Wish I knew this Friday, with the long weekend you could have gotten it all fixed.
Old 01-16-2012, 03:08 PM
newold928's Avatar
I just picked it up Saturday night swapped a wrecked 380 sl w/ 175k and a bad trans i picked it up at auction for $580.00
I let the car warm up by putting paper in front of the radiator got to about middle never over heated hit it with the heat gun 158 That's it .
Took out the paper dropped to around 137 heater blows Luke warm (had to pee twice).
once i got it around the lower temperature line the idle was just fine. i'm almost tempted to build an intake with a 850 holly on it.
Is there a cold idle control on this vehicle Porsche not Mercedes
Old 01-16-2012, 03:28 PM
Network Native
Danglerb's Avatar
Sounds like a thermostat issue.
Wow, I would have guessed that MB would have parted out for some serious cash.
Here ya go. Porsche : 928 Porsche : 928 | eBay
Old 01-16-2012, 04:46 PM
newold928's Avatar
Nah there a dime a dozen i trade crap like that all the time. I got a 76 f 250 i'm trading for two running GV yugo's. I collect strange cars. Fair lady 280 Z RHD 1966 Mini RHD 1965 toyota corona RHD 1965 datsun Silvia crap like that i sell a lot to car museums. I dont like parting out cars it has to be original or it's not for me
I will do the thermostat in the morning. rims say 16'' on the tire
Old 01-16-2012, 05:37 PM
MPDano's Avatar
Rjm65's 1979 US Model has 16's on it.
Old 01-16-2012, 08:26 PM
Network Native
Danglerb's Avatar
Make sure you get the correct thermostat and both seals. Some places will sell you a MB stat that doesn't fit. After you pull out the old thermostat there is a seal stuck in the middle of a smaller round tube opening that may need pliers to remove, but it needs replacing as well as the larger Oring seal.
Back in the days I was driving a 240z the shop got in a 2000cc early Fairlady, thinking 69 or 70, nice little car.
Old 01-16-2012, 11:24 PM
newold928's Avatar
This fair lady is for sale around me *********1979 NISSAN/DATSUN FAIRLADY Z RHD*******
I found that out I just ordered it on line with both gaskets. I ran some sea-foam through the tank today starting to run much better Changed the filter's Gas /oil Etc.
i want to do a trans flush and filter fluid change the good year by me can do it for 150 High estimate They have one guy that works on my Neighbors Ferrari 388 GTO i never herd him complain. His son takes the 850 M8 there no complaint's
The paint is new tires new 93834 Kilometer's (58kmiles) Small irritating issues i'm going to have all the bushing's changed /and shock's put the dial pads back on have the spoiler holes repaired. Have it checked out cleaned from the underside up.
i Talked to some friend's today.( they own antique car company's) They said that i am sitting on a very very nice car so i will put 4 grand in it and make it Right.
Back to stock and put her away
Old 01-17-2012, 04:54 PM
