nuts4porsche's Avatar
fuel pump relay
my fuel pump relay is rusty and shot,can i jumper the relay to see if it starts? does anyone have a pic of it also? 80 US auto-thanks all!
80 US auto
Old 04-10-2012, 06:56 AM
i remember a thread on here about it,dont know to much about relays so if someone can guide me through it that would be great. i have a jumper made just dont know which terms. to connect to.
80 US auto
Old 04-10-2012, 02:23 PM
MPDano's Avatar
If you look on the relay, it should have a diagram. I believe it's 30 and 87, but make sure someone chimes in to verify this.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-10-2012, 06:17 PM
MPDano's Avatar
I found this pic. It is indeed the 30 and 87
Old 04-10-2012, 06:18 PM
thanks so much,i didnt want to be wrong and have to put a fire out! i made the same jumper but in white so i could see it browning if it was wrong.thanks again i dont get to mess with her but here and there so its nice you guys are on it! i will be replacing the relay,just want to see where im at. bad wiring/relays in panel.
80 US auto
Old 04-10-2012, 06:39 PM
hers a pic of my FP relay,just to make sure 30-87 same numbers
80 US auto
Old 04-10-2012, 07:56 PM
stepson's Avatar
Yes. Terminal 30 has 12 volts. When bridged to terminal 87, it completes the circuit of the relay and allows the power to go to the fuel pump. On the spade end of the relay, the teminal numbers are stamped next to the male ends to help you know which is which. IIRC, terminal 30 is the male spade turned perpendicular to all the others and terminal 87 is the male spade directly opposite it.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 04-10-2012, 08:10 PM
MPDano's Avatar
Also, pretty sure each spade is marked with the corresponding number next to it's spade.
Old 04-11-2012, 04:23 AM
If you look at the bottom of the relay you'll see the spades are labeled. If you jumper the 30 and 87 connections, the pump will run continuously. If you jumper the 15 and 87 connections, the pump will only run when the ignition switch is in the on position. Jumping either bypasses the safety feature in the relay that shuts the pump off if the engine stops running during an accident, etc.
Dennis
Old 04-11-2012, 04:44 AM
sweet, thanks guys! the more info the better
80 US auto
Old 04-11-2012, 05:13 AM
Network Native
Danglerb's Avatar
You might also consider replacing the relay, less chance of releasing the magic smoke.
Old 04-11-2012, 11:49 AM
DPW928.....what is the mechanism that causes the fuel pump relay to shut off if the motor stops running? Am having trouble with a hot-start issue that gets resolved by switching out one fuel pump relay for another one that is "cool" after sitting in the glove box....wonder if it is temperature related.
Old 04-12-2012, 10:23 AM
The relay has to get a signal from the ignition module (circuit 31b IIRC) to power the fuel pump. It sounds like the relay has corroded connections or the wiring behind the relay panel is corrided. Any corrosion will increase resistance as the wiring heats up which could cause the relay to loose it's signal. If the external connections look OK, you might try pulling the cover off the relay and cleaning the contact. One other area to check is the ground that comes off the fuel pump and connects to the body. If that is loose or corroded it would affect the whole circuit. WYAIT I would check the battery ground also.
Dennis
Old 04-12-2012, 10:52 AM
Thanks, Dennis. That confirms my thinking that I'm going to have to do the long-put-off circuit board rehab I've been dreading...guess that is a right of passage all of us 928 owners have to do at some point!
Old 04-12-2012, 11:21 AM
im in the middle of doing it now,the back wires are done and im on the fuse spots on front now-not fun!
80 US auto
Old 04-12-2012, 11:30 AM
