Airtek,
Boises problem was the engine ran alright when cold but went lean as it warmed up. From reading your thread, your engine is starting with fuel from the cold start valve but you are getting insufficient fuel to the injectors to keep it running. My guess is that the metering slits in the fuel distributor are plugged with varnish from the old fuel. Try spraying injector cleaner through all 8 injector outlet ports to see if this improves the fuel flow. This may also clean varnish out of the distributors central cylinder which would cause the metering piston to lock. |
I would use a MB style FD only an an engine first properly tuned w/a stock FD. Following that, would add in the MB FD, adjust system pressure equal to what was there before (in-spec.). Lastly, perform individual cylinder A/F tune. In short, not for the faint of heart, but totally doable if systematic in process, while keeping variables to an absolute minimum. Def. not the right thing to do if the engine isn't running, or running right to begin with. |
lol...why not???
Dennis....good idea....When the injectors arrive (I hope tomorrow!) I will take loose all the lines at the FD, and blow through before I reconnect to the new injectors...will also clean or remove the little screens on the FD and WUR (cant play any tonight...it is VD)
Also, remove the fuel regulator off the back of the distributor, check the o rings and spray injector cleaner into the ports. It's possible the regulator was stuck open letting system pressure bleed back to the tank. BTW don't remove any spacers/washers on the regulator as they are factory set.
I'm with u on the $$ and time...I seem to lack both as well...
Dennis, when I pop the gas cap off, there is a sucking sound...so it does not appear to be pressurizing.....
There shouldn't be a vacuum in the tank if the lines are clear. You may want to check all your lines and inlets/outlets at the top on the fuel sending unit and between the fill tube and the back of the tank.
Huh? Oh boy...I'm screwed now! No wonder it ain't working!!!!
Dennis, perhaps it is air escaping, not sucking....? Gunnar...right? From the pharmacy? I need to drop in on you one day.... |
http://forums.pelicanparts.com/uploa...1360928828.jpg |
http://forums.pelicanparts.com/uploa...1360929737.jpg |
LMAO!!!
Jim, I got a buddy that owns a junkyard...I'll see if he has an old V8 benz lying around...may not, but ya never know... |
That's awesome, Gunar! lol Quote:
Just talked to my friend...he knows he has an old benz in the yard, and some volvo's...does not remember if they are v-8's or not, he said he would try to check today...
Airtek,
If you get an MB distributor, you will need to adjust the A/F mixture with the adjustor on the upper plenum due to the different geometries. The A/F mixture can be adjusted without the engine running. |
