Kool
AirtekHVAC's Avatar
thanks Dennis, but I am not looking for me...for Jim Doerr, I think he wants to play with one....If I cant clean mine out, I will try to rework it meself...if that does not work, I'll take it to the rebuilder near me.
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 02-15-2013, 10:40 AM
Just a side note for anyone adjusting their control pressure (WUR) or system pressure (regulator on the distributor). After changing either pressure, the A/F mixture will need to be reset.
For rebuilding the FD, a PDF document can be downloaded from the following site. http://www.porsche928forums.com/download/manuals/CISRebuild.pdf .
Dennis
Old 02-17-2013, 08:50 AM
Kool
AirtekHVAC's Avatar
That's the one that makes it look easy....lol...is it a trick?
Ron
Old 02-17-2013, 08:56 AM
No trick. If I can do it anyone can. Just take it slow, clean all surfaces, make sure the o rings are the correct size and recheck everything. The most common problem in DIY rebuilds comes from fuel leakage between the two halves since the 928 came with a steel gasket. Just make sure all the surfaces are flat and clean, then sparingly use a sealant if desired but make sure you don't block any of the small decoupler orifices.
Dennis
Old 02-17-2013, 10:21 AM
