Johnny V's Avatar
I just found a link to refurbishing the AFM that I may follow tomorrow. Here is the link:
Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk* ©2001 www.the944.com
1984 US 928S AT Black/Black
Old 10-11-2012, 08:36 PM
Kool
AirtekHVAC's Avatar
thats a good write up
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 10-12-2012, 04:18 AM
JK McDonald's Avatar
Fuel Pressure -
Hey Johnny, As you go over your car, the symptoms you are having sound more and more like a fuel problem. It is almost like your fuel rails are initially being pressurized but then the pump is not maintaining a sufficient fuel pressure to keep the engine running. I saw where you replaced the fuel pump and have jumpered the fuel relay - but have you actually checked the rail pressure with a gauge ?
You might put together a couple of brass adapters and a gauge to plug into the end of the passenger side fuel rail. This would at least visually eliminate one potential problem.
Good Luck, Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 10-12-2012, 06:44 PM
Johnny V's Avatar
Cleaned all the engine grounds today, except for the large one under the passenger side. I'll get to that one when I jack the car up.
I also opened up my AFM and looked inside. The track has some decent grooves and I've noticed the laser marks in the film resistors are very fuzzy. According to the pictures of a healthy AFM, those laser marks should be very defined. You can see what I'm talking about in the following picture:
Old 10-12-2012, 08:12 PM
