Starting Issue: Need Help
Hello 928'ers
For about two months now my 928 has been sitting in front of my house, motionless. It all started when one day things were fine and I turned it off to go to class, then when I came back, it wouldn't start. It cranked over, but wouldn't fire. Since then, here is what I have done: -New fuel filter (AdvanceAuto) -New fuel pump (928Intl) -New fuel line from pump to filter since mine had a kink in it (928Intl) -Checked fuel pump relay and even did the jumper trick -Checked injector relay -Cleaned ground points (The ones I could get to without a lift) -New battery -Took apart upper intake and cleaned everything -Took out the fuel level sensor and looked inside at the in-tank filter. Seemed fine. At this point I don't think it's the fuel system since it will sometimes start and idle for about 3 minutes, and then die. After that initial start, it will start for a second or two and die, almost as if it only tries to stay on when the car is cold. I looked at my throttle body and my throttle cable is a little loose, but I doubt that has anything to do with it. Also, there are two sensors by the cables; one that gets pushed when the throttle is full open, and another that seems to get pushed at closed throttle. They look like little gates with arms that get pushed down to hit a button. Anyway, the one that I'm assuming gets pushed on closed throttle isn't being depressed far enough down to hear that "click" of the button push..I don't know if that has anything to do with my issues, but I figure I'll mention it. I know I need air/fuel/spark for startup, and I am pretty sure fuel is fine at this point, as well as spark, so my suspicions are on the air part of the equation. Any help would be GREATLY appreciated as I hate to see my car just sit there :( |
I would inspect the fuel pump fuse holder on your CE panel
even the though you may have cleaned the fuse ends the holders get corroded inside the CE panel holder and thus wont pass voltage look above the CE panel for water tell ales if you see any then a blower box reseal should be on the list |
Can you hear the injectors working or tried a noid light on them? The car may be starting/running off the cold start injector. Once warmed up, the cold start injector disables as it should and since the injectors are not working, the car shuts down.
I'm going to buy a noid light today to test them out
UPDATE:
- Checked the injector harnesses with a Noid light and all 8 checked out fine. - Checked to see if the plugs were getting spark with an inline light, and they checked out fine as well. - Tested fuel system by jumping the pump relay and checking how much fuel gets returned in 30 seconds. I got 1.3L of fuel returned to the tank, which is right on. - Checked the vac lines on the fuel regulators, and none of them smell like gasoline - Checked the connectors for the MAF, temp II sensor, and cold start injector. All are intact in visually fine. After all of this, I cranked her over and after 2 tries, she started and seemed to hold idle well. I timed it, knowing it would die soon, and one minute and 40 seconds later, she sputtered and died. Cranked it over again, ran for 20 seconds and died. After this, the car will just crank over but not start. All of this is just as it was since I started diagnostics over a month ago. I checked the green ignition wire and the insulation at the plug is gone and I see some corrosion on the wire (see picture below). http://i78.photobucket.com/albums/j1...-23-59_565.jpg I forgot to plug it back in and tried starting it, which was a complete failure. I plugged it back in and it started for a few seconds and died, as usual. Also, I unplugged the temp II sensor to check if the CS injector was working, and the car started but it idled as if it were running on 1 cylinder, SUPER rough. I plugged the sensor back in, and it started and idled well for a few seconds, and died. Luckily, I'm learning to approach this whole thing with more patience. I'm glad that I have confirmation that my fuel system is running strong, and that all the plugs and injectors are getting pulsed. I'm planning on buying a new green ignition wire since I have been replacing a lot of old stuff anyway, and that is never a bad thing. Comments? |
wow yeah lots of patience and one heck of a thorough understanding of exactely what your car is doing good or bad when it does. and taking a component and knowing everything it involves.
gotta say the pcar knows when a microscopic piece of dust lands on itself. fiiiiickle and itll make you know itself as well as it knows itself, or be cursed. hehe. do you think someone may have put something in the gas while parked at school..... or you went to a different gas station or the gas station. drain it? bottle dry gas? o2 sensor? fuel damper carbonized ,air not mixing? |
At this point, I'm pretty confident the gasoline is not the culprit. It has fresh gasoline and has cycled a few litres of it to the engine and back. I'm suspicious of my injectors at this point, since I think it may only be running off the cold start injector and then dying once it stops spraying. The injector harnesses pulsing my noid light say otherwise, but at this point, I need more testing.
I just wanna drive my Porsche, dammit! lol |
Did you check the thermo time switch? It can cause it not to start.
off topic related water pump, tstat , timing belt - have you assesed whats under the black covers there at the front of your engine. nice that you wanted to get driving and have so for some time, yes? maybe time to pay dues. its cryin time again,lol
First pull your injectors and have them tested and cleaned. Find someone with an ASNU setup or send them off to one of the internet vendors. This assumes your temp II sensor has the correct resistance, your AFC also tests out. You can test the resistance at the computer or at the units directly. Should have the same reading. If not then you have a wiring problem. My guess is your injectors are getting electrical pulses but are so clogged they won't keep the car running. At least once cleaned you will have elimated them as a problem.
This may seem stupid but how's your gas? Did you get a recent fill up?
A lot of the tests your doing only show up whats happening on the start up mode
I don't see what year the car is ? But i would just try a known Injector relay / a fuel pump relay / test the coil ballasts ( they are 6 volt ) and look close at the coil wire as well as all the wiring open and clean the pin connector by the alternator > replace it if its all green and eroded away in places > Sound's like to me the car is starting on the cold start valve and try's to keep running but is not getting power of fuel after the cold start cuts off . my Guess is electrical power to the injectors or fuel pump stops > a relay |
You got it to start and run a little while after messing with the green wire, right?
Replace the green wire, see what happens. :) |
Green wire is a big suspect, you also need to try checking some things "quickly" when it won't start.
I hate to throw money at problems, but not running for two months is too long. |
Hey fellas. Here's the latest. I actually posted her for sale for a bit, then regretted it and decided to forge forward, lol.
My next step is to get injectors out of the question. AFAIK, they are original injectors, and I've been replacing/renewing so much, that I want these to be done too. My question is, where do I send these out, or do I just buy new ones (pricey) |
send the injectors to Witchunter and order a new green wire
Inspect the hard fuel lines from the tank to the engine bay , there have been a few cases where a jack was misplaced, and it crushed the line thus the engine would run till it ran out of fuel |
Witchunter, got it. As far as the fuel lines, I did the fuel return test and got 1.3L of fuel returned to the tank in 30 seconds, which passes the test perfectly. I really think the injectors are at fault and just want them taken care of, lol.
there is also a feed line to the engine if its damaged then the fuel pump will only pass so much volume of fuel,
once the demand for more is used then the crimped line may not be able to keep up |
Oh ok, I'll be sure to check the lines throughout
UPDATE:
- Removed fuel rails and injectors. They look bad :( The hoses are all dry rotting and they are filthy. I am going to send them to Witchhunter to see what they say since I'm not sure if those hoses are even replaceable along with the reconditioning they do. If not, I guess I'm going to have to save for new injectors. Here are some pics: http://i78.photobucket.com/albums/j1...-31-05_393.jpg http://i78.photobucket.com/albums/j1...-31-56_461.jpg -I removed the temp sensors for testing and I realized the connector on the one farthest back has a resistor on it.. is this normal? http://i78.photobucket.com/albums/j1...-04-32_870.jpg -I also noticed that two ports on my throttle body are capped off. My best guess is these are coolant line ports and the PO did a bypass? Still, looks shoddy and confuses me.. http://i78.photobucket.com/albums/j1...-52-47_459.jpg -My pin connector looks in decent shape. I don't see any problems here: http://i78.photobucket.com/albums/j1...7-49_756-1.jpg -I removed the shrouds for the timing belt to check it and see if it really was new like the PO said. Seems like he wasn't lying..unless I am judging incorrectly? http://i78.photobucket.com/albums/j1...-46-27_836.jpg http://i78.photobucket.com/albums/j1...-42-31_655.jpg -When taking off the timing belt cover on the passenger side, I saw this connector just hanging there. Not sure where it goes or if it was even connected to begin with. Anyone recognize it? http://i78.photobucket.com/albums/j1...S/Untitled.jpg http://i78.photobucket.com/albums/j1...-53-49_459.jpg |
So I looked into Witchhunter and they have instructions on removing the fuel injector hoses, and I found writeups on replacing those hoses as well. Good news! Since my car was running fine not even two months ago, the probability that they can be successfully serviced by Witchhunter and given new hoses is very high. They will be sent out this week for sure.
That connector looks like it is for the air conditioning compressor clutch.
The resister on the temp sensor is a "fix" for a bad running condition. It adds resistance to the signal which richens the mixture from the computer. The car probably had bad cold starts and or cold running issues. Dirty injectors could cause both problems. Check the sensor with an ohm meter at various temperature. You can pull the sensor out and use ice water and then heated water to test. The WSM has resistance ranges for different temperatures. If sensor is bad -replace. If good -continue to fix injection components.
Thanks fellas! I pulled the temp sensors and thermoswitch and will be testing shortly
Got my injectors back from WitchHunter today. I highly recommend them. I dealt with their second shop in Kansas. All of the injectors have new filters, gaskets, caps, and two of them had cracked insulators which were replaced. End result is that all 8 are perfectly matched and flow like new :)
http://i78.photobucket.com/albums/j1...-31-27_710.jpg I can now check off one more thing from my list of culprits. |
Really seems like the typical #2 fuel pump relay failure 911s go thru.
Fuel injected 911s of the same period have a fuel delivery relay located under the driver's seat that when fails will start briefly they die. Just as you are describing. Most people do not know there is an additional relay, i did not after 10 years ownership. I would look into whether 928s also have a second fuel delivery relay. |
The injector computer's ground may be bad. You need a noid test light to visually check for pulsing.
I checked all eight connectors with a noid light and all eight made the light pulse
Isn't the O2 sensor wired up with the fuel pump? I've heard about bad O2 wiring disabling the fuel pump before.
Not sure, but I have jumpered the fuel pump relay and it still won't start/stay on. I may be on to a lead that I will check on tomorrow. Hopefully I'll post back with good news.
Ok, spent a lot of time of the car today. Here is the list of what was done:
-Reinstalled injectors onto rails and then onto car -Cleaned injector harness ground -Replaced two large vac plugs on passenger side of throttle body (one had a huge tear) -Replaced small vac line connection to throttle body (hose had a cut right where it met the TB) -Removed strut tower brace (for stripping and polishing) -Reinstalled Temp II sensor, Thermotime sensor, and Temp sensor (cleaned them) -Visually went over every vac line I could see, found no more issues I jumpered the fuel pump relay so I could fill the rails and lines with fuel first. Once that ran for a bit, I removed the jumper, replaced the relay and gave it a shot. Unfortunately, the results are the same. The car hesitated for a bit (shaking off the cobwebs from sitting for about a month), then started. It stayed on for about a minute or two(ran pretty well), and then choked up and died. I tried it again, started for a second, then died. After this, it just cranks with no start. Also,if I press the gas pedal at any time while its running, it chokes and dies. If I let the car cool for a while, and try again, it starts then dies quickly after. So, my next step is to order a new thermotime sensor, temp ii sensor, and green distributor wire. I'm also going to order a new battery ground strap since I peeled back the insulation and it looks like this: http://i78.photobucket.com/albums/j1...-13-58_881.jpg http://i78.photobucket.com/albums/j1...-14-09_202.jpg I really thought it was going to stay on after fixing those vac leaks and getting my injectors serviced. Sucks that it's still fighting me, but I guess I can check a few more things off the list of suspects.. |
I'd say you've found the problem - it's the ground strap! Replace that before anything else, it matches your symptoms very well. Ie. "works fine, works fine, suddenly goes wrong"
Lol, we'll see in a few days when it gets here
Yep. May want to replace the engine ground cable, too. $8 at Autozone.
Replaced my battery ground strap today. Easier starting.
Tried out an emergency start today learned at RL. Yellow wire in 14 pin to jump post to by pass the ignition switch since mine has been giving me some grief. I think that is a good thing to know. I hope you figure out your issue(s). We all have them at some point. |
Cam Timing - Check
Hey Johnny - From following your problem, it looks like you have checked off most of the basic issues that might have caused your problem. Have you actually placed your crankshaft at top dead center and then cross checked the cam timing marks to be sure they are still set correctly. You would probably find it easier to line up everything by using a large socket/breaker bar on the crank bolt with the plugs removed. Naturally you must make sure to be on the #1 cylinder compression stroke.
I have seen several cases where a running 928 was shut down only to jump a tooth or two on the cams because a new timing belt had not had the follow-up adjustment performed after replacement. Just a thought - Good Luck, Michael :) |
Thanks for the tip, Michael! I actually have not performed that check. I assumed my timing was fine since it runs smooth for the minute or so before it dies, but I'll check regardless
Ok fellas, my new sensors came in today and of course they sent the wrong one for the thermo switch. However, temp II and the temp gauge sensor were the right ones. I replaced those two and I also installed the new ground strap for the battery.
I tried to start it and same as before, it would try, start and then die. I then wedged the barn door open and tried again. It started right up and ran like dog $hit, however, it did not die. It even allowed me to rev it up. Once I got off the gas and let the rpms settle, it ran like it was misfiring, but it ran. I then removed the wedge I had in the barn door and the car died almost immediately. I disconnected the AFM completely and tried to start her up. She starts every time and runs horribly, but doesn't die. Again, when it's running, it lets me rev it up without dying, but runs BAD. I also noticed my dash voltage gauge is reading much more stable with the new ground strap and my courtesy lights on the doors are way brighter. PROGRESS!! I'm now going to get the correct thermo switch sent to me, as well as look into replacing my AFM. I'm assuming the running like crap is normal with a disconnected/dead AFM. Seems as if those sensors were never the issue, but I'm glad I have new units regardless. I'll update once I get my AFM situation resolved. |
Your thermotime switch is working fine. It controls your cold start valve. Save your money.
You may need to open up your AFM and increase or decrease the spring tension, and clean up the slide and arm. You may have too much resistance between the arm and the slide screwing everything up.
| All times are GMT -8. The time now is 12:35 PM. |
