Starter won't come out
I own a 1982 928. I can't put it up on ramps because of the front spoiler. I jacked it up and pulled the bolts out of the starter but it won't come out because of some cross-member or stabilizer bar is blocking it by about an inch. Do the front tires have to be on the ground or do I have to remove the bar to get it out?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
i dropped the bolts on mine and came right out.the manual tells and shows how to remove.
80 US auto |
928 Newbie
Sounds like your motor mounts are collapsed and that is making your motor hang too low.
VERY CAREFULLY using a nice thick block of wood, carefully jack the motor up about an inch or 2 (very carefully as your car is on jackstands. ~~ You need to get a low profile jack for these cars.) With your motor the correct height the starter should pivot clear the anti-roll bar. Last edited by dcrasta; 06-11-2012 at 05:37 PM.. |
Petie3rd
other option here is to remove the rear sway bar clamps to chassis, then drop the rear of the bar ,
the starter will then drop out. WARNING I would not put the rear wheels on ramps then jack the front, if the E brakes are questionable then the car could easily roll forward with the rear wheels coming down the ramps and the jack rolling forwards. Better to jack the car up and put jackstands under each jacking pad
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
928 Newbie
