Pressure Damper problem??
while replacing cracked vacuum hoses in my engine bay I pulled the vac line off the fuel pressure damper and when I did, I noticed it was wet , not the damper itself , the vacuum hose. As in it was wet with gasoline, so I blew it out (the damper which was apparently full) and reattached the hose and started the car for a few minutes, then shut it off and checked the damper again which was once again full of fuel .
my questions are : 1) is this normal? 2) if not , does this mean that the internal diaphragm is shot and I need to replace the damper ? 3) is this dangerous?
1984 928S either Metallic Pewter or Quartz Gray |
1. no
2. yes 3. possibly, you will suffer performance wise as well as emissions.
My Car: 84' 928 S with Euro Mods - Quartz Gray Metallic (Quite the project!) |
Sounds like a bad damper diaphragm to me, but the best way to test itis to use a hand operated vacuum pump and attach it to the damper. If it holds a vacuum it should be okay, nut if the vacuum bleeds off, it's time for a new one.
