Graphic engine images: what's missing?
Okay what's wrong with this picture. I'm trying to put this back together but with the baby and the actual full time job I'm very sleep deprived. Do you see anything missing or any issues whatsover? Any parts I should replace now from what you see? Thanks
Old 06-25-2012, 10:17 PM
Sorry for the disturbing nature
Old 06-25-2012, 10:23 PM
Network Native
Danglerb's Avatar
Did you use any kind of assembly lube?
Old 06-26-2012, 01:33 AM
Porsche Fanatic
Tom's 87 928 S4's Avatar
Did you buy this car?
porsche
1987 928S4 White Auto
1984 Euro 928S Dark Green 5-Speed
Old 06-26-2012, 04:48 AM
harborman's Avatar
This is a real can of worms! Was it put together properly? What was done and was the person qualified? What was wrong initially?
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 06-26-2012, 05:38 AM
Fabio421's Avatar
That crank pulley looks like it was put on backwards to me. Is that even possible? Anyone else?
1984 928's w/ 5 speed Smoked Quartz Metalic
1982 928's Turbo w/ 5 Speed Platinum Metalic
1978 Euro Widebody w/ 5 speed Guards Red
Old 06-26-2012, 05:54 AM
porsche
Tom, you're smarter than you're average panda. What was your impression when you spoke to the guy? Strange fellow but price is right if I haven't bit off more than I can chew. I hate coming into the middle of someone's project. Even things you know look right you still wonder about.
Old 06-26-2012, 06:46 AM
Pete R's Avatar
not possible... with the same bolt anyhow.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 06-26-2012, 07:19 AM
stepson's Avatar
Yep. Looks backwards to me, too. It is possible with the same bolt. Just ask me.
Good catch, Fabio.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 06-26-2012, 08:54 AM
Pete R's Avatar
Good catch, Fabio.
seriously, how? isn't the mounting surface all the way at one end. If you flip it over the bolt will be like 4 inches too short, no?
Neon SRT4 track car
Old 06-26-2012, 09:06 AM
Architecture & Porsche's
1. Your chain tensioner oil supply line on the one head shot is not installed yet.
2. The main "vacuum line" on the bottom of the TB is not present on the front picture: this is the large line that eventually goes to the brake booster & intake manifold side plenum (driver's side).
3. One of the far right water pump bolts is actually about 3" long as the bolt holds the plastic cover over the water pump: test fit that.
4. Numbers on the crank pulley are read from looking at the front of the engine: if read from the windshield side, that's incorrect.
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 06-26-2012, 09:08 AM
Pour oil over all the cam lobes/lifters and turn over once, then do it again before you install the valve covers: a good preventative maintenance item since it'll be a dry startup.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 06-26-2012, 09:09 AM
928 Newbie
dcrasta's Avatar
I dont see the timing belt tensioner.. Am I just being blind?
Old 06-26-2012, 01:35 PM
Intersting: it isn't there, but the Air pump bracket that's part of the tensioner housing is: might need more photos on this part...hmm.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 06-26-2012, 01:37 PM
I do not think that is the AP bracket but the AC bracket - needs a PKensioner 8>)
www.************
Old 06-26-2012, 03:01 PM
Pete R's Avatar
The ac bracket is there, the tensioner/air pump bracket is mia
Neon SRT4 track car
Old 06-26-2012, 03:38 PM
Network Native
Danglerb's Avatar
So far it sounds like, take it apart, put it back together slowly checking everything.
Old 06-26-2012, 11:54 PM
Tags
928 , disaster , engine rebuild
