-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Tried to fix a/c created another problem (http://forums.pelicanparts.com/porsche-928-technical-forum/685982-tried-fix-c-created-another-problem.html)
Mpierick 06-27-2012 06:36 PM
I have a vacuum problem with my air cond controls. I took out all the controls on the center consolee to get to the vacuum lines. I found the loose line and put it back. I then put back all the other controls and when I started the car the instrument gauges stopped working. Well sort of!!!!. The "information" button is illuminated and when I push it the tachometer works but reads over 2K at idle. When I pull the hand brake the tach dies and the information light comes back on. The oil gauge sometimes works. Is it safe to assume I loosened a ground wire when I dove into the console or did I blow a fuse somewhere.
Also the flashing emergency light on the instrument panel stays on. I hope I made this clear enough.
Any ideas???? Thanks
stepson 06-28-2012 09:17 AM
Sounds like a ground issue or two plugs got swapped in your reassembly.
Dean_Fuller 06-28-2012 10:24 AM
Did you remove the pod?
Mpierick 06-28-2012 10:37 AM
Thanks for the response.
Dean, since you mentioned it I did venture over to the pod because the high pressure washer button was broken. I had to remove some items, such as the lower pod trim. When I looked at the electrical connection it only had one wire going to it. Like a dummy, I pulled on another wire of the same size thinking it should be connected to the other side of the button. I might have pulled something loose over there or does the button only have one wire to it? I am very bad at electrical diognostics. Thanks.
Mpierick 06-29-2012 04:38 AM
Good news. I spent well into the dark last night looking for the problem. Well, I decided to check the fuses. I found a blown 5 amp fuse that is in slot 10. Lesson learned. Look at the fuses first.
Thanks for your input.
