Need help pod smoking by ignition
I started the car to clean it, then smoke started coming from pod. I found a harness with three wires connected to a white slide that goes into a silver bar in the pod just under the ignition switch. Plug is black with three wires. I need help anyone knpow what this part is????
Old 07-08-2012, 11:00 AM
Any help here?
Old 07-08-2012, 11:52 AM
garylewa's Avatar
Can you post a picture of the area?
'83 928S - Basalt Black Metallic w/Cocoa Brown leather
Old 07-08-2012, 03:53 PM
Dean_Fuller's Avatar
What model car? A pic would help.
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's)
1989 Auto Slate Grey Metallic / Cashmere & Black (mine)
1982 5-speed White / Black sport seats ( brothers )
Old 07-08-2012, 04:10 PM
1984 928 s Sorry, do not knowhow to post pics
Old 07-09-2012, 02:09 AM
When you hit POST REPLY...below the dialog box there is a CLICK HERE TO UP LOAD A PHOTO...Then BROWSE , select pic from your pics folder. You may have to resize to a smaller file size before hand.
Or if you use another site to host pics ..just link to that.
Old 07-09-2012, 08:55 AM
Not sure on the 84 model but my ignition switch on my 89 attached to the back...the keyed part is NOT part of the switch.
Is it just the wires that burned? Was the insulation worn and they just shorted? When the ignition switch goes bad all kinds of odd stuff happens. Headlights may be a no go, widows may not operate, car may not start, ect...
Old 07-09-2012, 09:01 AM
pic of burnt part
I will try to attach pic
Old 07-09-2012, 11:30 AM
garylewa's Avatar
I've had my pod and cluster out a million times (it's all documented on this forum ...........) and I do not recall anything that looks like the picture you posted. It looks factory to me though. The only thing that is below my ignition is the wiper button and a thumb dial.
Old 07-09-2012, 03:05 PM
Kyle C
I have seen that on my car. It's on the underside of the steering column member that connects between the steering column and the ignition lock cylinder. I think I located it in the wiring diagram. If I am correct, it is wired into the door chime/timing relay in the center console. I will post a picture of the diagram.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 07-09-2012, 06:32 PM
Kyle C
If the circled switch is the correct one, it switches power from fuse #23 to terminal 85 of the "timing relay" (door chime/seatbelt warning lamp timer). So it would make sense that this is the switch which makes the chime sound off if you have the key in the ignition, but I haven't verified this yet.
Old 07-09-2012, 07:28 PM
Ibeleive wegot it. Now, every time I open the door with or withoutthe key in the ignition, I hear the chime. I will need to more the slide to the off position and am not putting the part back in.
Old 07-10-2012, 02:22 AM
