1982 928S
georges 928S's Avatar
RE: oil around throtle body
today i noticed oil around throttle body were intake goes into the 3 inch diameter with the round rubber piece,do you guys think it is coming from the intake or the 3 inch rubber piece. Thanks Ed.
Old 10-12-2012, 08:21 PM
DZGunner's Avatar
idk why but i have oil getting into my throttle body too, havent figured it out yet
1987 s4
Old 10-13-2012, 10:07 AM
1982 928S
RE:Throtle body leaking oil
I've attached pictures of that area for you:
Old 10-13-2012, 02:14 PM
Network Native
Danglerb's Avatar
Likely the breather or a related hose, the thing with the yellow knob.
Old 10-13-2012, 05:11 PM
Kyle C
I have noticed that the poorly set up crankcase ventilation system on the 16V motors tends to coat the internals of the intake with oil which then seeps out around the 8 rubber boots on the spider legs of the intake as well as the throttle body boot and other rubber vacuum hoses. I ended up removing/capping of the vacuum hose that runs to the oil separator (filler cap) and it currently vents to the atmosphere.
If you remove your lower air filter box and peek into the bottom "U" in the intake, is there a small pool of oil present?
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 10-13-2012, 07:58 PM
Network Native
Danglerb's Avatar
There are better, wiser solutions than venting the crankcase, which is what those breather lines do (safely route it back to the engine intake for combustion.)
Old 10-15-2012, 03:17 AM
Kyle C
I agree, I would like to get a Sharkvent or similar system but until then I don't want my intake getting coated in oil again. The stock setup doesn't do a very good job separating the blow-by gasses from oil vapors
Old 10-16-2012, 03:57 PM
SanDiego928's Avatar
I found a little oil, enough to wipe off with a finger on the inside bottom of the AFM where it snugs into the O-ring.
Any concern I should have?
What is a sharkvent?
Mark
1981 928
Old 10-16-2012, 06:57 PM
1982 928S
Hi Danglerb, how do re-rout the venting hoses to the combustion, can you send a picture or drawing on that if possible. i would appreciated very much. thanks Ed.
Old 10-18-2012, 07:45 AM
