Madman
Dash Restoration; Check it out.
Well I dont know if this is the best place to post this but anyway.
So I decided that I was fed up with messing around with half broken and half corroded dashboard connections and so I decided to completely rewire the entire dashboard through some "dub D" connectors.
Bought materials.
new color coded wiring diagram:
I decided that since so many of the components had either constant power, constant ground, or both I would make a "central harness" :
Labeled the back:
Then I soldered a plus or minus to each of the lights where applicable and ran a "signal wire" also to each light, attached and soldered terminal connectors to the wires going to the gauges.
At this point it was like "Yikes this is A mess, Hope I can finish it"
But I just had to neaten it up a bit, organize the wires, and attach the connectors (keeping track of the wires and making a new version of the diagram of course).
Here's a close-up of the 25 pin connector:
I havn't installed it yet because I still have to do the dash in car wiring for the connectors. but it should work well.
1979 Porsche 928 3sp auto, black (gone)
Yamaha FZ6R, Raven Black. (gone)
1997 VW Jetta GLX VR6 swap in. black (gone)
1988 Jeep Cherokee 4.0 lifted, mudders, roll cage, black (wife's)
Old 09-07-2010, 09:54 AM
Network Native
Danglerb's Avatar
I've thought about that, hope it works well.
Old 09-07-2010, 10:09 AM
MPDano's Avatar
Damn dude! Ingenious. Please give us an update once you get it all connected.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 09-07-2010, 10:58 AM
928: Serial Enabler
Thanks for showing that!
Old 09-07-2010, 12:23 PM
Dash Restore
Anthony,
Very nice job, will be an inspiration to others.
Old 09-08-2010, 04:03 AM
harborman's Avatar
Lots of work, hope it pays off!!!!!
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 09-08-2010, 05:58 AM
Madman
Thanks for the feedback, I'm making the final connections in the car today ill update on how well it works!
Old 09-08-2010, 08:56 AM
Nixon's Avatar
Very nice. I would love to rewire my whole car but I'm still a little timid. There's about a dozen or so of you "hard core" guy's in here that give the rest of us the will to keep the faith with these cars. Great idea hope it works well..........Nix
Old 09-09-2010, 09:30 AM
Nixon's Avatar
Funny, I just noticed all your responses are from the guys I'm talking about...... Nix
Old 09-09-2010, 09:33 AM
Madman
Installed.
Well I got it fully installed at about 1 AM last night. It works great from what I can tell. I cannot start the engine right now because I am about to do a head gasket. However the voltage gauge, fuel gauge, and all the lights seem to read /work properly. the temp and oil pressure gauges jump to "zero" from rest so it also seems that they work. Ill just have to wait to start the engine to see if the tachometer and speedometer work; ill make sure they go all the way up.
I also moved connectors "M" and "R" over to the left which required unwrapping and re-wrapping the dash wiring harness.
Here is a couple of pictures:
Before:
After:
I also gave the backlight optics a new coat of silver, cleaned and repainted the dash backing (in between the gauges).
Now I just have to work out some issue with the central warning system turning most of the warning lights on partially, I dont know if this is a "prove out" process or not. It had this problem before the rewire too and I double checked all my wiring with a 12v power source and there are no crossed wires (each light can come on individually). I dont know what is causing it.
Old 09-09-2010, 01:20 PM
stepson's Avatar
Great Job Anthony!
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 09-09-2010, 02:21 PM
Good work, I just had to rewire all the connectors on one of mine, PO had cut them all off....I may ultimately end up doing something like you did.....the flex circuit is NLA and I have one circuit run destroyed....
Old 09-09-2010, 03:06 PM
stepson's Avatar
Tmpus,
Are you coming to Third Coast first weekend in Nov?
Old 09-09-2010, 06:14 PM
Originally Posted by stepson View Post
Tmpus,
John,
I am not certain about attending yet. Would like to meet the others in the area, it mostly depends on getting one of our two 928's in presentable/road worthy condition as well as working around some other travel commitments for the month....
best regards,
Jim D
Old 09-10-2010, 03:43 AM
Yes, it is true...
legendary's Avatar
Send a message via Yahoo to legendary Send a message via Skype™ to legendary
great work - would love to see how this turns out
Best Regards,
Leon M
Old 09-26-2010, 09:15 PM
stepson's Avatar
Originally Posted by tmpusfugit View Post
John,
best regards,
Jim D
Hey, the first Third Coast I attended was with the Stepson which had no door panels, no radio, no A/C. It needed tie rods and shocks all around. It was the most fun I ever had to that point with my clothes on. Just get one running/drivable and come on over! You will be amazed at the amount of knowledge you will come away with.
Sorry for the hijack, but it looks like a great job, Anthony!
Old 09-27-2010, 07:07 AM
John,
the car I hope to drive needs a dash, which I now have, but it needs to be recovered...also the car has been driven a total of 400 miles in the last 8 years. Oh yeah, the TB and WP have less than 2000 miles on them, put in 12 years ago...I have not yet powered it up, have been reconnecting all the cut off wires and correcting other minor problems and putting things back together from PO's planned changes....
Starting point looked a bit worse than it really was, but a lot of work remains to get it back to ready for the road...I suspect if I can make it, it will be in the white one....I have logged 3000+ miles in it in the last 3 months, following TB/WP etc etc
Jim D
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red)
Old 09-27-2010, 08:37 AM
Does anybody want or need a new set of VDO gauges...the PO was planning to use these in the red 928. I am returning to stock....
Old 09-27-2010, 08:47 AM
Maleficio's Avatar
Very slick work! Very nice.
You may want to replace your central warning unit. Mine was completely dead, bought a used from 928worldwide (now shut down) for around $30. Works great.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 09-27-2010, 10:07 AM
Wow! What awesome work
I just thought that old 928s were destined to have screwy instrument panels and that's the way it is.
If you can get that part sorted out, everything else is easy
Mike S.
79 928 Racer 427ci 32v 640WHP
Old 09-27-2010, 02:29 PM
