DZGunner's Avatar
Door jam light
Does anyone know how to gain access to the bulb in this? Mine have never worked and I wanted to see if the bulbs were ok or not. I didn't know if there was a way i could just pull them out if i needed the door apart to access them, thanks guys.
1987 928 S4 - Guards Red
Old 06-16-2013, 10:32 AM
por917's Avatar
You can get a fine screwdriver and pull it out, or remove the center panel where the pull handle is and access it there. Just pop the two plastic clips on the top and slide it aft.
Rich
Newnan, GA
1981 928 Coupe Black/Tan
Sunroof delete
Old 06-16-2013, 10:47 AM
DZGunner's Avatar
ok, i'll go try this, thanks
Old 06-16-2013, 10:52 AM
DZGunner's Avatar
It worked, and it's pretty obvious as to why they dont work, lol. They were completely rusted, so bad that i'm gonna have to cut them off and buy new ones.
Old 06-16-2013, 11:09 AM
por917's Avatar
Don't cut them off you should be able to pull the wires off the contacts and just plug in the new sockets.
Rich
Newnan, GA
Sunroof delete
Old 06-16-2013, 11:25 AM
Network Native
Danglerb's Avatar
I am planning on LED conversions so when the stupid door pin switches don't work at least the battery will drain more slowly.
Old 06-16-2013, 12:09 PM
por917's Avatar
Here's an idea fix the door jam switch when it fails
Rich
Newnan, GA
Sunroof delete
Old 06-16-2013, 12:45 PM
DZGunner's Avatar
you dont understand, there were no terminals left, when i took the sleeve off, it was just rust, lol, i have to cut them off, i'll crimp new terminals on and i have some new lights ordered already because the whole assembly was so messed up.
Old 06-16-2013, 02:14 PM
DZGunner's Avatar
also, if someone can find an LED to fit this, please point me in the right direction, i've already made all my interior, center console, and POD lights LED's, im trying to make every last light an LED
Old 06-16-2013, 02:15 PM
DZGunner's Avatar
This is why i ended up buying new ones... Will install new terminals also obviously.
Old 06-20-2013, 05:19 PM
por917's Avatar
Yes I had the pass side one looked just like that. I was able to pull the tab out and clean it up pretty good, but installing new terminal ends is no big deal also. Good luck with the LED conversion.
Rich
Newnan, GA
Sunroof delete
Old 06-20-2013, 05:52 PM
Network Native
Danglerb's Avatar
I am thinking find a new modern light off something else that fits the square hole.
Old 06-20-2013, 07:48 PM
Petie3rd
Mrmerlin's Avatar
put a dab of silicone on the wires as they go into the rubber boot this should prevent water from running down the sheathing and filling the connector area
Old 06-21-2013, 09:48 AM
MPDano's Avatar
JB Weld
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 06-21-2013, 10:13 AM
MPDano's Avatar
I would do what Mike suggested. Just wire up a single LED and RTV it. No more metal to rust and it's sealed. Done!
Old 06-21-2013, 10:15 AM
Network Native
Danglerb's Avatar
Did some google, saw nothing special I liked, but square LED with reflector can't be very rare, just need to find the right catalog etc. to look in.
This looks wild, but very rice, it projects the cars emblem on the ground when door is open. Look at the very bottom of listing to see what it does.
2X LED 4th Gen Car Door Courtesy Laser Projector Shadow Light for Porsche Series | eBay
Old 06-21-2013, 12:33 PM
harborman's Avatar
You can buy jumbo LED's at Radio Shack. You will need a resistor in series to drop the voltage for the LED. It's value will depend on the operating current and voltage of the LED.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 06-21-2013, 01:00 PM
MPDano's Avatar
..or just buy this one, no resistor needed, remove the nut, shove in hole, rtv the open hole, done.
Red LED with Holder : LED Holders | RadioShack.com
Old 06-21-2013, 02:27 PM
Network Native
Danglerb's Avatar
I want stock or better, which means I want about the same size, reflector back, as well as low current LED.
I am wondering about difficulty fabricating something. Start with a fair sized reflector, dremel, file, whatever outline of a shark, glue/goop a good sized LED on the back. Other shapes optional except for mud flap girls.
Old 06-22-2013, 06:29 PM
DZGunner's Avatar
lol, that would be interesting to have the emblem on the ground. I may end up rigging an LED into this like you guys have been talking about. I just wish there was an LED that fit the given socket. I can make i my own stuff though i guess...
Old 06-22-2013, 10:44 PM
